PT LE 7.4 no longer works on 3 different PCs
Hello all.
As of last week, I cannot get PT LE 7.4 to start on my computer, a Windows XP. The program will not load at all and the specific error I am getting is: "The application failed to initialize properly (0x80000003). Click on OK to terminate the application." I have uninstalled and reinstalled using the clean install from the cd and tech support program available on the site. I have tried rolling back to 7.3 and updating to 7.4cs. I have tried uninstalling all of my plugins, PACE drivers, and any programs installed recently that may be conflicting with it. As well I tried updating drivers for my Mbox2 hardware, ilok, etc. I even tried system restore. I thought I would have to reformat my drive, but the strange thing is, we did a test and tried installing PT on two different computers, both Vista, and we got the EXACT same error and number string. I am starting to think the problem is a windows update of some sort conflicting with PT. I have searched elsewhere for this error and there are only a few specifically relating to PT, some mentioned in DUC, but they all suggest things I've done and it doesn't seem anyone's been able to fix it. In my research of the error conflicting with programs other than PT, I found a lot of people just had to update their Microsoft Visual Basic C++ and .NET Framework, and I've tried that too, with no results. I'm at my wits end, my software was working perfect till a week ago, and there are projects I need to work on. Below I will post my pc specs with SiSoftware's Sandra Lite as requested. I do not have the specs for the other two comps we tested on as they're not mine, but if totally necessary I will try to get them. I have already sent a message to Digidesign Support, but thought I'd post here as well. Please, any help would be wholly appreciated, thank you. Quote:
Re: PT LE 7.4 no longer works on 3 different PCs
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
Did the problem start on 12/12? Do you use Panda 2008 anti-virus? If yes to both, Check the logs to see if Panda has suddenly (incorrectly) found some Adware programs or DLL's. Remove Panda 2008, restore the files falsely removed, and update to Panda Pro 2009.
Thanks for the replies.
I already did a system restore to 12/8, the day after the last time I used it (couldn't go farther back) and it didn't work. I don't know what day the problem started honestly, but it was sometime within last week. I can't remember the exact day I first saw it, cause I thought nothing of it at the time and thought it would be a quick fix I could get to later. Nope, I don't have Panda anti-virus, but I have Avast. Up till now I've just deleted everything potentially harmful (I know, I shouldn't have...), but I'm looking at the logs, and I don't see anything like DLLs within the timeframe of the problem occuring that have been deleted. I'm going to try looking at the security updates installed within the timeframe as well as see if I'm missing something in the logs. EDIT: Yeah, I'm looking at my logs some more and I don't see much I've deleted in months. Also wondering if it's okay to uninstall all the security updates from that week. Hmm... |
I run updated windows XP & 7.4cs3 with a digi003 experiencing none of your problems.
(*knocks on wood, crosses fingers) I remember seeing updates for XP about the time you started having trouble.
exploration x |
Lol, I hope you didn't jinx yourself either. =b
Yeah, I figured it isn't that widespread since I couldn't find much info on it. But who knows? I'm still confused why it came up with three diff comps. Oh cruel fate... =( |
spdif no longer works on 8.01 | latiffee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-30-2009 06:46 PM |
click no longer works? | pk_hat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-15-2005 09:18 AM |
OT: FireWire no longer works...... | ronev | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 06-30-2003 10:56 AM |
Waves 3.0 no longer works with HUI | Huby SEA | Pro Tools TDM Systems (Mac) | 2 | 11-18-2000 07:45 AM |
CMD- SPACEBAR no longer works !!.. | Lo | Pro Tools TDM Systems (Mac) | 5 | 05-30-2000 07:29 PM |
