Old 05-24-2004, 09:35 AM
ronan73 ronan73 is offline
Default mbox latency working methoods
so i am finally starting to do some live sessions with the mbox and i find this 164 sample rate thing
allmost impossible to handle in a fast live session
how do you people out there work it out
i find it ruins rhe work flow when you have to punch alot and then if you forget to shift once it becomes a mess and you have to zoom in all the punches to make sure
i am sorry no body menthioned this before i got my box i might have re considered
Old 05-24-2004, 10:05 AM
MikeSoloway MikeSoloway is offline
Default Re: mbox latency working methoods
It was my understanding that this latency problem is fixed with the latest ProTools. But I am fairly new at this. But I had read this in some other posts on this site.
Old 05-24-2004, 10:58 AM
Correct.
Quad 2.5 G5, 4.5G RAM
Old 05-24-2004, 03:14 PM
Tubz Tubz is offline
I usually wait until the session is over, then I shift back the tracks and make a little note in the commentsbox. Just checked a HD 2 system today, it had 77 samples of recording delay....
BR Tubz
Old 05-24-2004, 04:36 PM
i havent seen anything in the forums about this problem being solved on the 6.4 but i am gone run and look it up right now it its true i will be thrilled
thanks
Old 05-24-2004, 11:35 PM
mobilemac'nstrat mobilemac'nstrat is offline
Be thrilled, it's true. The Mbox 164 sample recording latency issue is fixed in 6.4.
Strangely, Digi seem not to have confirmed this, despite previous posts asking that they do so.
A quick search of the answerbase shows this new 'bug' :
"MBox Mac doesn't correctly update its latency compensation when switching between analog and digital input. Using Pro Tools LE v6.4"
and advice for a workaround. The phrase 'latency compensation' would appear to refer to the 164 shift problem, but is ambiguous, especially when the old tips for shifting by 164 are still there as well
Please Digi, clear up this confusion by confirming the 6.4 fix and ammend the 164 shift tips to apply only to versions before 6.4.
Old 05-25-2004, 12:01 AM
The Mink The Mink is offline
What's the word Digi? Very important, right?
iMac 2.8 GHz Intel Core Duo, 4G memory
OSX 10.6.8
PTLE 9.0.5, Mbox 2 Pro
Dynaudios
Organic French Roast
Old 05-25-2004, 12:32 PM
linpaws linpaws is offline
yes please clear the air, digi, it's confusing !
Paul
Old 05-26-2004, 03:31 PM
Just saw Digi tech support seem to be awake and replying to recent posts.....
....any chance of an answer here........?!
Old 05-27-2004, 05:39 AM
Hanslemonverm Hanslemonverm is offline
Digi please?
Low Latency Monitoring not working- MBox Pro steveos69 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 35 01-10-2013 03:37 AM
omni/native latency vs mbox pro latency chrisdee Pro Tools HDX & HD Native Systems (Win) 34 03-30-2012 07:24 AM
Low Latency on PT HD9 not working either acmost Pro Tools 9 0 11-13-2010 07:14 AM
Low Latency Mode Not Working? Jet Recording 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-26-2008 07:55 PM
Low Latency Not Working! Has Anyone Solved This?? orangepopsongs 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-24-2007 11:56 PM
