MBox 2 Pro problems - no sound (Windows XP Pro)
My MBox 2 Pro has apparently stopped working......
1st of all - yes, i have checked my drivers, etc in Device Manager. It says the device is working properly....and YES, I of course checked my cable connections, etc etc. I DID see that the "SM Bus" driver had the yellow "!" next to it. I googled it and it said basicly that driver controls the managment of power (electric) and thus manages temperature of the motherboard (this is where I got a little nervous....). So I updated it. I don't think it did a damned thing. Probably a waste of time too. I didn't notice the conditions get any worse afterwards, mind you. I use the MBox as my ONLY sound card on my computer, i.e., Reason, Windows Media Player, etc - all use this hardware, and quite well...until now. I first noticed the problem when i tried to play a .wav file, a rough pre-master i did a week or so ago. i loaded it up on WMP and the play bar was moving, the lame "tie die" graphics moved to the beat of the music and everything...just no sound. the first thing I did was check the connections. All good. So I thought if my MBox were malfunctioning then surely PT wouldn't run, right?...............Pro Tools ran just fine - the faders lit up, counters were counting - everything was great except NO SOUND. I tried pluging the Firewire cable in the 2nd port on the back of the MBox, still with no avail. I also know that unless your firewire port lacks power than it is not neccesary to plug a AC adapter to it. I tried it anyways....still nothing. I REALLY HOPE SOMEBODY HAS AN ANSWER FOR ME - since it is IMPOSSIBLE to get someone on the phone......................:ma d: |
Re: MBox 2 Pro problems - no sound (Windows XP Pro)
You say it stopped working, so I assume you had it working befor ?
1) Have you checked that your Mbox is the Default playback device under : Control Panel -> Sound and Audio Devices -> Audio ? 2) Have you tested with headphones ? 3) Have you installed Quicktime ? http://duc.digidesign.com/showthread.php?t=133039 4) Have you used the Tech Support Folder (for Pro Tools 8) to trash preferences, remove plugins, delete pt folders, etc ? http://www.digidesign.com/index.cfm?...4&itemid=25974 5) Do you have service pack 3 (sp3) installed ? http://www.digidesign.com/index.cfm?...5&itemid=22905 6) Have you heard about paragraphs ? I can't se you are saying what computer system you got. Are you shure it is supported ? http://www.digidesign.com/index.cfm?...gid=1&eid=6757 |
/Program Files/ProTools and double click DigiDrivers. Click Present Device Audio Driver and launch Pro Tools.
filosofem |
OKAY - this is weird........i just turned on my PC and TADA - i have sound again! I didn't do anything more since the last time I was on it...
it works now... (????) i dont know what the hell is going on......but i appreciate you two getting back to me so promptly. I'll keep you guys posted....as i am sure something else will come up |
I actually think this may be a power issue......I have a 30" Samsung monitor for which I had to install a bigger power supply. I was reading on Intel's website about the SM Bus driver. This driver apparently regulates power distribution for the motherboard. My girlfriend was editing some photos on Photoshop for over 8 hrs, so maybe it just shut off the sound card to conserve power, and prevent overheating......
I don't know - like I said...weird |
No sound from MBox 2 in Windows | Guesswork | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 08-05-2012 01:28 PM |
no output sound on Mbox 2 pro, windows 7 | Myke79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-10-2010 01:09 PM |
mbox 2 pro mini...windows 7...no sound? | kruciallvc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-16-2009 07:47 PM |
Problems with MBox 2 and Sound Forge 9 (Windows XP) | theagenda | Pro Tools M-Powered (Win) | 3 | 07-08-2007 12:30 PM |
Mbox and windows xp crackling sound | Jakob Frandsen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-09-2004 05:05 AM |
