Old 12-20-2015, 12:02 PM
tattootroy tattootroy is offline
Default What does purple color plugin on insert means
What does purple color plugin on insert means?
I add metric halo channel strip and the color is purple what does it mean ?
File Type: jpg Screen Shot 2015-12-20 at 7.59.48 pm.jpg (13.2 KB, 0 views)
Old 12-20-2015, 12:25 PM
Ghost In The Attic's Avatar
Ghost In The Attic Ghost In The Attic is offline
Default Re: What does purple color plugin on insert means
Run out of the room as quickly as you can.
Oh wait, that's the color green.
A purple insert identifies a partially bypassed plugin.
Open it up and you will find some part of the plugin in bypass.
Retro 176 (pair), Pultec EQP-1A (pair), Germanium Comps (pair), BAE 10DC (pair), Distressor (pair), Manley Vari-Mu, Sta-Level, Zener, SSL Fusion, SSL FX G384, API 2500, LA2A, 1176, Bricasti, Massive Passive, Anamod ATS-1, Eventide H3500, TC 2290, Yamaha D5000, PCM92, PCM70... Amps, Amps & More Amps.
Old 12-20-2015, 12:42 PM
Ohh cool thanks i was only using the noise gate on it
Old 12-22-2015, 09:59 AM
escobardaniel's Avatar
escobardaniel escobardaniel is offline
Dynamic session is bypassed.
CPU spikes after plugin insert Jperkins Pro Tools 12 23 01-21-2016 04:00 AM
Table pf plugin automation statuse color [email protected] macOS 2 07-13-2014 05:19 AM
MH ChannelStrip 3 Insert Tab in PT 11 is Sometimes Purple? RokVox AAX Plug-ins 7 12-06-2013 10:35 AM
Plugin Active Parameter Color Indicator midnightsun ICON & C|24 2 07-31-2009 03:49 AM
insert plugin order 4times4mil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 11-13-2006 03:22 PM
