Help exporting single midi clip from multitrack
Let's say I have a session with 4 midi tracks: piano, bass, pad and drums but I only need to export the bass track so I can edit it with an external application. Is there a way to do that? Thanks!
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
Re: Help exporting single midi clip from multitrack
Do you want to edit it as MIDI or audio? If audio I'd render it to a new audio track and export that. You should be able to export single tracks.
Hi musicman, I forgot to specify that I want to export it as midi. Thank you!
You should still be able to export a single MIDI track. I know PT's MIDI implementation isn't the greatest but I'm curious - what other program are you going to edit it in?
I don't see the relevance of that, Ableton Live 9. I know I could export the entire multitrack session and delete the midi information I don't need but also I should be able to export only the clips of my choice. Could you imagine how much trouble would it be if this was a 48 midi tracks session?
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com Last edited by amagras; 09-18-2015 at 06:29 PM. |
Select the midi clip and choose Export in clips bin menu.
Impossible, all the Export options are greyed out on Vanilla, don't know about HD
Are you looking in the clip bin (used to be called region bin) menu? |
I did exactly as you describe provided that the clip bin menu is the one that pops up from the right
Then I don't know, sorry.
Exporting a single Midi Region | EachHit | Pro Tools 10 | 6 | 04-14-2015 11:02 AM |
Exporting track stems. Why is HD required for multitrack bouncing? | DJ Hellfire | Pro Tools 11 | 7 | 10-24-2014 12:10 AM |
Can you pan a single clip? | SWBoatman25 | Tips & Tricks | 3 | 04-19-2014 01:17 PM |
Editing a single clip in the MIDI Editor Window | MogDog | Pro Tools 10 | 5 | 10-22-2013 07:05 AM |
Exporting Single MIDI Track | GTBannah | Pro Tools 9 | 8 | 01-30-2012 05:44 PM |
