Old 02-10-2002, 09:52 AM
fe.martin fe.martin is offline
Default RECORDING GUITAR DIRECT
This may sound silly, but I've recorded guitars directly in the 1/4 inch input of the digi001 and the signal is very weak( I DO NOT HAVE A MIXER). Do I need to run through a pre amp? Has anyone done the same thing?
Thanks,
Fernando [img]images/icons/confused.gif[/img]
Mr. Mix
Old 02-10-2002, 10:20 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: RECORDING GUITAR DIRECT
Is the guitar pot turned all the way up? Is the mic pad switch pressed? Have you gone to the input page and adjusted the gain higher?
When you say the 1/4" input, do you mean the rear inputs? Those are line inputs. Try the front inputs.
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 02-10-2002, 10:27 AM
Mark_Knecht Mark_Knecht is offline
It works on the front inputs as long as you don't have the pad inserted.
The sound can be somewhat 'different' though...
Mark
Old 02-10-2002, 11:52 AM
gerax gerax is offline
Guitars' pickups put out a very weak signal (that falls in the mV range) so it's no surprise that your guitar signal is so low: that's the reason guitarists "usually" go thru a preamp; you can surely use the ones built in 001, but they're not specifically designed to treat a guitar signal; this doesn't mean it's not going to work, you'll get a different tone from the instrument (direct sound), which in selected cases can be the thing you need; forget about getting "big" guitar (and amp) sounds this way, you can get very clean plain flat sounds that can be killer for some rythm parts or clean arpeggios (think 80's kinda sound), or you can go with a plugin like Bomb Factory Sans Amp to get a distorted one, but again it will be no substitute for a real guitar/amp/mic combination.
Cheers
L.G. [img]images/icons/smile.gif[/img]
Old 02-11-2002, 12:37 AM
Gr0und_Zer0 Gr0und_Zer0 is offline
Behringer V-Amp!
Hehehehe...
Cheap. Good. [img]images/icons/grin.gif[/img]
Old 02-13-2002, 03:42 PM
Jopry Jopry is offline
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by fe.martin:
<HR></BLOCKQUOTE>
Save yourself a whole bunch of time and use a guitar amp and mic or direct out of the amp into the digi. If you do not, more than likely, you will end up pretty unsatisfied with your guitar sounds.
Jared O'Pry
Old 02-14-2002, 05:23 AM
YOU ARE RIGHT!
I DO MIC THE AMP ALSO. BUT BECAUSE OF NEIGHBORS I CAN'T HAVE THE AMP ON. SOMETIMES I DO THE RECORDINGS A LITTLE LATE.
BUT DEFINITELY THE SOUND OF AN AMP AND MIC IS THE REAL THING!!
THANKS
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by Jopry:
<HR></BLOCKQUOTE>
Mr. Mix
Old 02-14-2002, 01:38 PM
digitaltoast digitaltoast is offline
You need a direct box! Mic and guitar signals operate at different impedances. You get sound that is week. In fact different mics operate at different impedances, high end mic pre's let you adjust the input impedance, check out the Alesis Vipre or Digi's new PRE.
Old 02-14-2002, 02:55 PM
Cinemafixer Cinemafixer is offline
I bought a Mesa studio20/20 last week used for 150 bucks - You can use it as a pre for guitar (sounds great) and you can mic it when permitted (sounds great, not too loud)...
Old 02-15-2002, 01:59 PM
YOU ARE RIGHT!
THANKS
<HR></BLOCKQUOTE>
Yeah, I know what you mean about the neighbor thing. When I get the urge to rock out at 3 am, I go into a Boogie Triaxis, then bring the outputs direct into the digi (dry, add effects later if you need or want). I often like the sound so much that I tend to mix it with a mic'd amp track or even by itself for a final cut. As a side note, this works exceptionally well on an Ovation acoustic too. Happy strummin' [img]images/icons/smile.gif[/img]
Jared O'Pry
Recording guitar direct + guitar cab TDub 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 07-09-2010 02:21 PM
Help with guitar recording direct to DI loki01 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-15-2008 02:15 AM
cheap direct guitar recording? dannypassenger Tips & Tricks 6 02-18-2005 02:33 PM
Recording Acoustic Guitar Direct Boozer007 Tips & Tricks 24 08-07-2004 07:04 AM
Recording guitar and bass direct - help! halfloaded 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-07-2002 04:35 PM
