Old 11-02-2001, 11:24 PM
tomhartman tomhartman is offline
Default Question about Clearing Unused Regions...
When you select "Select Unused Regions" then choose "Clear Selected," even though I hold the option key down, I still have to OK about 10,000 dialog boxes before it will delete the regions. Is there anyway around this nightmare?
iMac 27
Old 11-02-2001, 11:36 PM
polyorchid polyorchid is offline
Default Re: Question about Clearing Unused Regions...
If you are just clearing selected the bits you are throwing away are still in your hard drive. You could delete, but you still have to hold down the enter or return button. shift-control-u, shift-control-b is the key command to get there.
The other way to clear everything that is'nt being used in your session with out the thousands of "are you sure...?", is to select all of your used regions in your edit window then "compact selected." This will clear everything that is'nt being used in your session, so do this at key times in your session like the very end or before laying key parts then backing up.
polyorchid
Old 11-02-2001, 11:37 PM
One more thing, dont do this if you are using those files on other sessions that are sharing audio from the same audio folder, because those other sessions will never find those files again unless you recover them from a back up.
polyorchid
Unused Files Clearing Ozman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-30-2008 06:12 PM
clearing unused regions/disk space jameynate 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-20-2007 12:08 PM
compacting files and clearing unused regions Rasan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-11-2004 09:56 AM
Clearing out the unused Audio JesseF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-16-2004 12:58 AM
Clearing unused regions and backing up songs! Bastiaan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 09-11-2002 12:30 PM
