I have a question about cleaning up unsed audio. Selecting "select unused regions" and then clearing (deleting) selected does remove a lot of garbage. However, "Save Session As" choosing to save audio files, seems like the only way to really clear up ALL the garbage. My sessions have shrunk by gigs by using this command. Ismt there a way to raelly clear all the unused audio without "saving the session as"? -JF_ |
doesn't anyone know or are you all just too shy? Or is the answer just so obvious that you dont want to waste your time? Or have I stumped all you??
Here's the deal. You think you're clearing out all that unused audio, but you're not. By REMOVING Unused, you are telling the session not to use these master files. BUT! they still remain in the Audio Files folder.
That's were you see the difference with Save Session Copy In, because it only takes the Master (Parent) files that it needs to recreate the necessary regions in the timeline. I feel that "Selecting Unused" is unsafe. If you choose DELETE, you end up trying to delete parent files that regions are pointing to. PT will tell you, "hey man, I can't lose that file, cause it has stuff that I need. Do you wanna REMOVE it?" So you say yes... and all you did was tell the Session to not load it, but it's still taking up space in the Audio Files folder. This is all a BIG part of understanding how PT works. File management is a big part of being a good operator. You've already figured this out with Save Session Copy In. Yes... this is your best bet if you want to get the session size down safely. Only the necessary Parent Files will remain intact. I always use "Select Unused Except Whole Files". All this really does is clear out the Region List/Bin and make the session run snappier. To get the session size down I use... Save Session Copy In. Does this all make sense? |
Clearing unused sides of stereo files | gonzolagonda | Pro Tools TDM Systems (Mac) | 2 | 02-03-2011 09:13 AM |
Unused Files Clearing | Ozman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-30-2008 06:12 PM |
Clearing out unused media in sessions | stanonbass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-18-2005 09:00 PM |
Remove versus Delete when it comes to clearing unused audio... help! | tommydee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 01-26-2002 01:19 AM |
Question about Clearing Unused Regions... | tomhartman | Pro Tools TDM Systems (Mac) | 2 | 11-02-2001 11:37 PM |
