  #91
Old 01-15-2021, 09:34 AM
analog orange analog orange is offline
Default Re: Anyone tried Protools on an M1 mac yet?
NeilMc,
You’re maybe the only one that can answer this question.
Is your m1 Mac mini with 16gb ram as powerful or more powerful than the intel Mac mini?
I have a maxed out 2018 Mac mini, 64gb ram etc.
I think there's only one app I run that wouldn’t work under Rosetta sooo it has me thinking.
I’ve opened mine up and given it external cooling as well because of the heating issues you also experienced.
It’s a great little box but when you plug into every jack and run it like a Mac Pro it’s a sweaty little dude.
If it matters, I'm running Protools Ultimate.
Kind Regards,
Justin
Originally Posted by NeilMc View Post
I've been running on a 16gig Mac mini M1 for a couple of weeks now.
Clean install of 2020.11
No serious testing, but it runs all of my long form work without breaking a sweat.
Sonarworks is running fine under beta.
Sony, Isotope, and Nugen needed Rosetta to install.
Dialogue Isolate using RX, which made a 6 core mini very hot indeed and arced up the fans doesn't even seem to warm up the M1, and is considerably faster.
The only thing which (unsurprisingly ) doesn't work are the HD Drivers, which won't load, even using the terminal commands.
So no HD Omni for now.
Still, it looks promising.
  #92
Old 01-17-2021, 04:52 PM
NeilMc NeilMc is offline
Originally Posted by analog orange View Post
NeilMc,
Kind Regards,
Justin
Hi Justin,
I can't really give you a definitive answer, sorry.
I had a mini with the same configuration as yours, but only for 2 weeks, when I sent it back to Apple.
When in lockdowns I work in a small home studio (bedroom) and the fan noise from the mini drove me nuts.
Im a bit OCD about noise, running on SSDs etc.
My dialogue tracks are usually noisy enough without the mini adding to the confusion.
The M1 is deathly quiet so far, and a wee bit warm at best.
I am running Ultimate too.
Until Avid write new drivers, I can't use this rig professionally, as I am monitoring through HD native thunderbolt with an HD Omni
The maxed out 6 core is an amazing computer- if not for the fan noise I would have kept it, for sure
  #93
Old 03-18-2021, 09:49 AM
tonejunkee tonejunkee is offline
Anyone word on the M1x macbook? Looking forward to a cooler, quieter and lighter machine. I basically want to be able to import an entire film and score it, with scads of tracks, plugins and zero hiccups. I may have to wait till 2025 to do that on a laptop due to the compatability
I'm still running a 2011 MBP with PT12...
2011 MBP / PT 12.7.1
OSX Yosemite 10.10.5
16GB 1333 Mhz DDR3
2.3 Ghz Intel Core i7
Noise Buffet
  #94
Old 03-18-2021, 04:42 PM
ZEUSS ZEUSS is offline
That would be amazing. Too bad Pro Tools is terrible with VI's...
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
  #95
Old 03-22-2021, 08:58 AM
budster budster is offline
This should probably be a new thread, but has anyone successfully gotten their HDX cards working on the new M1 machine running Big Sur? I've been testing a new Mac mini with 16 gigs of RAM running ProTools 2020.11 successfully. I took the computer to work and hooked it up to my HDX Sonnet chases, installed the HD drivers but no love. I feel like the OS will not allow the HD cord driver to be properly installed. Any thoughts or successes with this?
Buddy
PT Ult 2020.11
Mac mini M1 16GB
  #96
Old 07-06-2021, 02:03 AM
MEYSLIE MEYSLIE is offline
Has anyone tried to install HDX driver on M1 using UAD´s instructions for Reduced Security option
https://help.uaudio.com/hc/en-us/art...atibility-Info
Start the computer in macOS Recovery
Shut down the computer.
Press and hold the power button on your Mac until you see “Loading startup options.”
Click Options, then click Continue.
If requested, enter your account password.
Set the security policy
Note: You need to keep the security policy settings below (even after UAD installation) for UAD software to function.
In the Recovery app, choose Utilities > Startup Security Utility from the Menu Bar at upper left of screen..
Click on the system drive you want to use to set the security policy.
Click Security Policy, select the Reduced Security option, and enter your password if requested.
Check the “Allow user management of kernel extensions from identified developers” option.
Click OK, then restart your Mac for the changes to take effect.
Import session protools 8 mp vers Protools 12 [Résolue] eryck Le Forum en Français 5 10-18-2016 11:54 AM
Protools 12 - Input Audio Window Keeps on opening Protools Cache soundman1234 Windows 0 08-25-2016 11:27 AM
changing from protools 8 audio only to protools 8 with video support djkaz macOS 5 09-04-2013 04:00 PM
ProTools Shortcut keys suddenly became disabled in ProTools LE 8.0.5? jgbsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-03-2011 01:08 AM
setting record levels into ProTools with the intent of mixing in ProTools Felix Tips & Tricks 507 02-05-2002 10:17 PM
