Old 04-09-2019, 01:05 PM
Top Jimmy's Avatar
Default Re: Any way to stop Pro Tools from changing sample rate automatically?
Originally Posted by arn87 View Post
Hi Robpert, I'm having the exact same issue, this is driving me nuts! How did you fix it?? Thanks
You don't fix it. It has been reported to Avid that session sample rates are changing when they shouldn't be able to, but tech support doesn't seem to think this is an issue.
If it happens to you where you saved the session after the sample rate changed, you'll need to create a new session at the correct sample rate and import session data everything making sure to uncheck the option to sample rate convert. The original files haven't changed their sample rate, it's just Pro Tools that thinks the rate is different than what it should be.
James Cadwallader
Old 03-11-2020, 05:20 PM
signalme signalme is offline
Uninstall ASIO4ALL, restart, then install it again.
Pro Tools 11 automatically changes sample rate when opening infamy Pro Tools 11 16 02-27-2015 06:45 PM
Focusrite Saffire 56 Sample Rate Problems - Sample rates changing during start up finalcut Windows 12 02-20-2012 04:00 AM
Changing Sample rate from 96 to 44.1 langelo68 General Discussion 4 08-29-2009 08:18 PM
Changing the Sample Rate jimbojimbo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-12-2007 05:07 PM
CoreAudio-Sample rate automatically switch to 44.1 thepantsdancer Pro Tools TDM Systems (Mac) 0 12-23-2005 08:23 AM
