#21
Re: 2020.3 on Mac Pro 5.1, High Sierra?
That's what i've tried. Same video card then you, downloaded from the App store, etc.. I did not work until i tried with a regular drive. Then, bingo! It worked. And i was able to install it on my SSD drive after that. So now it's working. Pro Tools 2020.3 on High sierra working just fine Thanks Padje for the tip |
#22
Good to hear. Now keep that in mind when you eventually upgrade your GPU to Metal compatible and update to Mojave
#23
Funny, I have a 2009 Mac Pro. I flashed it to5.1 and installed Sierra. I thought that when it is flashed to 5.1 if Sierra works, High Sierra should. The only problem I had was my High Sierra installers were not working because they were out of date and I had to knock the date in my computer for the installer to work. When I did that it loaded fine.
2009,2012 8 Core Mac 5.1, (32 gigs Ram), MSI Radeon 570,s 2011,17 MacBookPros , 828MKIII Hybrid, 828X , 8Pre, OSX Mojave 14.6,High Sierra 13.6, DP11, PT2024.3 , Peak 7, Logic 9 ,WaveLab 11,Cubase Elements 11,Reason 11, DSP-Quattro 5.5 ,many plugins , mics and synths. http://www.panaccimusic.com |
#24
So it seems there are a bunch of tricks you might need to try to get those flashed 4,1 --> 5,1 cheesegraters to accept another firmware update
#25
Yep. Thanks for your help Janne!
#26
No problem
#27
Just adding that my 4,1 to 5,1 flashed Mac pro running Sierra runs 2020.3 with no problems mixing fairly large surround sessions to picture.
Richard Spooner Ultimate, S1, Dock, Monterey , MacMini 3.2 Ghz 6-Core i7, 64gb RAM. www.spoonsound.com |
#28
I'm on a ssd since 4 years. Last year I've upgraded sierra to hs and during the process it asked me to update the firmware. I did it. All worked fine. But maybe (don't remember exactly) it asked me the firmware update when I was still on the usb stick hs installer, because I usually upgrade the OS by formatting the Os disk then do a clean installation.
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11 Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7 |
#29
I can also confirm that the High Sierra 10.3.6 clean install, and more recently Mojave 10.14.6 clean install ran without issue, on my cheesegrater 4.1 updated to 5.1 with SSD OS drives (Samsung EVO).
But after the original 4.1 to 5.1 firmware flash, I later replaced the mobo, processors and Ram, to get 2x 6-core 3.46ghz processors, 64gb ram, so it is now seen as a genuine 5.1. Maybe that makes a difference, or maybe the specific make/model of ssd makes a difference. Had 2020.3 running for two days now, left on overnight too. Approx 10 mixing across the two day, and about the same trial and error working on template ideas incorporating a basic folder hierarchy to organise things, and updating my track presets. I’ve shied away from using routing folders for now, because of reported issues going back a while where complex sub routing played havoc with plugin delay compensation where audio goes via multiple paths that each result in different plugin delay total amounts. I modified my workflow to keep multiple routing paths for audio to a minimum, and above all simple. All audio and instrument tracks are routed directly to my mix buss, with sends on those tracks going to aux track fx busses that then route to the mix buss, and other sends on those tracks going to aux track parallel compression busses that also route to the mix buss. I avoid aux tracks having sends to other aux tracks because of how many paths with different total delay values a single audio source may end up travelling. That problem may have been fixed now, I have no idea really, but I haven’t felt the need to back to my previously more complex routing setups. Simple works for me!
Mac Pro 2009 with 2010 firmware, 12-Core 3.46ghz, 64gb RAM & working Thunderbolt, OS 10.14.6 and Windows 10 iMac 2012 27", 3.4ghz i7, 32gb RAM OS 10.14.6 Digi 003 Console for control surface only, Focusrite OctopreLE and MOTU Traveler for extra analog-ADAT conversion, UAD Apollo Quad Silver with Thunderbolt card, Apollo x4 and pci-e Octo, Adam A77X monitors. Pro Tools 2022.4, Media Composer 8.9, Sibelius 8.7, Cubase Pro 11, Wavelab Pro 11, Logic Pro X 10.5.1, Mainstage 3. Various apps, soft synths, FX plugins. Plenty of hardware synths, rack gear, microphones etc. And then there's the studio ;-) |
PT 2020 to require Mojave and drop High Sierra support? | XJENSEN | Pro Tools 2019 | 10 | 03-28-2020 11:54 AM |
Question: Sierra or High Sierra for PTHD 2018.3? | johnnyv | Pro Tools 2018 | 25 | 03-18-2018 08:30 PM |
PT-First with high Sierra? | LarsT | Pro Tools | Intro Discussion | 1 | 12-30-2017 12:08 PM |
High Sierra | jeffpardo | Pro Tools 12 | 28 | 12-20-2017 09:39 AM |
High Sierra yet? | mlavin00 | Pro Tools 12 | 18 | 11-13-2017 10:09 AM |
