Remove overlaps and leave gap...
Re: Remove overlaps and leave gap...
I'm not sure I follow, but on some tracks, if I want a space, I just select the area and hit delete
Ok, my bad. Poorly explained.
It's a dedicated feature. Event operations > change duration. There, I can choose to remove any overlapped notes, and set a user-definable gap. Very handy when using a legato mono synth sound where I want portions of the performance to NOT be legato.
Works ok here on 10.3.8, also worked in 9 for me. Is is possible it's a selection issue? I've sometimes had event operation windows fail to see the current selection correctly and only by re-selecting the passage can I get them to apply properly. Also check that you have 'limit range' switched off, as I think this is on by default and can cause it to ignore some notes.
Thanks for the tips, but that's not it. I'm not aware of any more ways to select notes or clips, and limit range is off. I can't make it work with notes or clips, not in the edit window and not in the MIDI editor.
I've also opened two other sessions, and this feature doesn't work there either.
Hmm interesting. The MIDI region you are trying to apply it to - what is it and how was it generated? Chords or single notes, played in via keyboard or software created? On a MIDI track or an instrument track? Have you tried consolidating it to a new region?
If you upload a copy of one of your sessions I can have a go and see if it works on my system. |
Have you tried doing this through "real-time midi properties"?
Ben Rubin Producer//Mixer//Bassist//Composer benrubin.com ------------ PT Ultimate 2024.3, Mac Studio M1 Max, 64Gb RAM, Mac OSX 13.6.4, SSD sample drive, Neve 8816, HD Native Thunderbolt, (2) Lynx Aurora 16, Benchmark DAC-1/ADC-1 |
Link to the session below. Thanks a lot. https://www.dropbox.com/s/acy038qnj1...iking.ptx?dl=0 Quote:
Ok so I downloaded your session and tried it, and sure enough it doesn't work at all. But here's the kicker - now when I open my own sessions it doesn't work in them either!!! It definitely did when I tried it yesterday!
WTF? Am trashing prefs now... |
Ok mystery solved. The 'remove overlaps and leave gap' function only works on overlaps of the same note. That's why it worked for me yesterday, I was working on a kick drum channel at the time so tried it out with 2 C1 notes. Excerpt from the manual below:
midi event operations 'remove overlaps' doesn't work | Dan Gralick | Pro Tools 9 | 1 | 11-01-2011 05:36 PM |
Midi export creating note overlaps + gaps | tombliss | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 12-18-2010 10:13 AM |
Bouncing Quicktime video - intro plays slow, overlaps middle vision, then no credits. | accession | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-19-2009 06:06 AM |
Does remove PT - remove projects too? | Andy Gerome | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-29-2008 11:29 AM |
Add/ Remove Programs will not Remove Pro Tools | powerjoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-07-2005 02:48 PM |
