Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
  #101
Old 10-28-2020, 09:36 AM
midnightrambler midnightrambler is offline
Default Re: Folder Feature Requests
Zoom toggle should automatically open a closed folder. What the hell is the point of looking at a blown up "overview"? Literally none, that's what. It drives me bananas to have to toggle in - toggle back - open folder - toggle in, just to see the appropriate tracks.
This would be the first thing I would change anyway if I was an AVID god.
  #102
Old 11-03-2020, 07:14 PM
Drywsef Drywsef is offline
If it hasn’t been said already, Avid should really expand the alt-key “do to all” contention to the shift-f open/close folder command. We should be able to open and close all folders with a single keystroke. This seems like an oversight.
Win 11 22H2 - PTU 2023.9 - HDX - Blue 192 - Prism Titan
i9 10900K, Asus Tuf Gaming Z490 Plus, Corsair Vengeance LPX 32GB, NVIDIA 1070ti
OS/apps, sessions, and samples all on separate drives.
  #103
Old 11-04-2020, 01:08 AM
DrewHarrison DrewHarrison is offline
Default Re: Independent View of Folders in Mix and Edit Windows
Originally Posted by ejinbc View Post
I also really wish they had implemented automatic routing when you drag a track into a routing folder (expected this) - would be a great workflow for quick grouping functionality.
THIS!!!
Pro Tools 2022.12.0
Mac Pro 2019
OS X Big Sur
  #104
Old 11-04-2020, 01:13 AM
Originally Posted by metalmixer View Post
delay compensation with plugins on routing tracks add plugins on the folder track with any plug cause all the tracks in folder to go out of sync
I had that issue until I rebooted Pro Tools There must have been something funky going on - I deleted the folder tracks called drums (same name as my group) called it something else rebooted and it fixed it.
I think this is a manifestation of the same bug I'm getting, but I'm getting it more often and it's much harder to fix. I started a Thread on it under "Pro Tools 2020".
Pro Tools 2022.12.0
Mac Pro 2019
OS X Big Sur
  #105
Old 11-04-2020, 08:03 AM
THIS!!!
I'm not sure I'd want this without user's consent. I just moved up a bass track to line it up with the kick drum, but there's no way I wanted the bass to suddenly come out o the drum busses.
  #106
Old 11-04-2020, 08:22 AM
Agreed. I can see a lot of situations where automatic routing would be undesirable, e.g. I often move my guide track into the dialog track folder for reconforms, and I wouldn't want to route the guide track to the dialog bus. I think it would be better to have the Move To New Folder shortcut (Cmd-Opt-Shift-N) actually be a Move To Folder shortcut with a dialog box that allows you to move to a new folder or an existing folder, with or without automatic routing (via checkbox). Or create a new shortcut (Cmd-Opt-Shift-F) that is Move To Existing Folder, also with or without automatic routing.
Scott Gatteño
  #107
Old 11-05-2020, 01:31 PM
Someone suggested Cmd+Drag, but a warning or yes/now popup window would also work. Or maybe the option to decide in the preferences.
Pro Tools 2022.12.0
Mac Pro 2019
OS X Big Sur
  #108
Old 11-13-2020, 02:17 PM
NateAlexander NateAlexander is offline
And really as someone mentioned, the behavior should obviously be (at least optionally) that muting a folder mutes the children tracks AND sends! what other possible reason would someone have to must a folder unless they didn't want to hear everything inside of it at all.
  #109
Old 11-16-2020, 12:14 AM
danyg danyg is offline
suggestion:
- moving and draging tracks in the arangement is rather an for comparing files so no automatic routing is applied.
- using "right click track" and "move track into folder" is obviously for re-routing otherwise I could just drag and drop it. (maybe with a preference option that can be changed)
Mac Studio - Ventura- 64 Gb ram - SSD int 2T - SSD ext 4T - Antelope Galaxy 32
  #110
Old 11-19-2020, 01:48 PM
Has anybody checked to see if 2020.11 allows folders to be opened/closed during recording? I'm guessing not, but never hurts to ask. I am waiting to update until after I finish a few big projects.
Scott Gatteño
Feature Requests janmuths General Discussion 3 07-18-2010 02:28 AM
Feature requests DamonMoritz Aspera DigiDelivery 1 05-03-2007 05:46 PM
Bugs, feature requests and tip requests! Basil Rush Pro Tools TDM Systems (Mac) 6 12-07-2005 08:21 AM
new feature requests! (again) mattm Pro Tools TDM Systems (Mac) 11 04-14-2002 09:30 AM
A few feature requests: uno1234 Pro Tools TDM Systems (Mac) 32 10-12-2001 01:28 AM
