Old 02-26-2014, 11:49 AM
NBarnes21 NBarnes21 is offline
Default "Clean Uninstall" Pro Tools 10 after moving over to Pro Tools 11?
Hi all,
I've had PT10 and PT11 co-installed for several months but am finally able to fully move over to PT11 since most plugin companies have caught up. I want to uninstall PT10 now as I have limited drive space on my laptop. Is it safe to do a "Clean Uninstall" of PT10 and still have PT11 function completely? Do I need to "Safe Uninstall"? Any help is much appreciated, thanks!
Old 02-26-2014, 12:35 PM
lancemcv's Avatar
lancemcv lancemcv is offline
Default Re: "Clean Uninstall" Pro Tools 10 after moving over to Pro Tools 11?
I would think a clean install would be the way to go. But I would clone your system drive first just to be safe. You could then boot off the clone and run the clean uninstall on it, instead of your internal boot drive, and see if it works there. If it does you can then do the uninstall to your internal system drive.
Maybe someone else will chime in and tell you you can do it without worry, but better to be safe than sorry.
Old 02-26-2014, 04:45 PM
Post Re: "Clean Uninstall" Pro Tools 10 after moving over to Pro Tools 11?
Do a Clean Uninstall.
The Safe Uninstall option is only for people who have Media Composer co-installed on the same system.
Old 02-26-2014, 05:16 PM
dr_daw's Avatar
dr_daw dr_daw is offline
Hopefully you're not on Mavericks
FBR recording - https://www.facebook.com/fromthebase...cordsrecording
@FBRrecording - Instagram
Rig
MBP 15" High Sierra 10.13.3, i7 2.6Ghz, 8Gb DDR, 750Gb 7200rpm, PT 2019.5, Focusrite Saffire Pro 40, Octopre MkII, Glyph GPT50, Avalon 737sp, AMS Neve 1073's, API 512c, CAPI 312's, DW drums, Fender Guitars/Amps, AKG, Rode, Sennheiser, Neumann U87 & KM184's, Coles 4038, Equator D5 monitors
Old 02-26-2014, 11:29 PM
Cool, clean uninstall it is!
I thought PT11 was Mavericks compatible?
Old 02-27-2014, 01:44 AM
JFreak's Avatar
JFreak JFreak is offline
Yes it is, but PT10 is not. You cannot uninstall PT10 on Mavericks, that's the problem. So what I recommend is take the time to do a clean complete re-install starting from backing up everything, wiping the system drive, and installing OSX again.
Janne
Old 02-27-2014, 05:32 AM
hakofred hakofred is offline
I have been working with the same problem. I accidently updated to Mavericks while still running PT 10. I updated to PT 11.1.2 and couldn`t uninstall PT 10.
I installed Mckeeper which solved the problem for me. I was able to use the Application to succesfully uninstall PT 10. I am now running Mavericks 10.9.2 and PT 11.1.2 flawless With some minor bugs. That saved me for a lot of trouble
Imac 21,5 late 2012, (upgraded 2018), i7 quad core 3,1 ghz 16 gb ram. Samsung Evo 850 SSD 1tb. Catalina 10.15.3, PT 2021.12, Waves Diamond ++. Native instruments komplete ultimate. Arturia Matrix 12v2. Mini V v3, Prophet v3, Air , Hammond B3x
etc...
Old 02-27-2014, 07:14 AM
Ah, good thing I'm still on Mountain Lion. I did a clean install of Mountain Lion when I upgraded and actually moved everything back over manually and it was a huge PITA, could I just use migration assistant this time to move stuff back over from the backup drive after wiping and clean installing Mavericks? The biggest pain was reinstalling and activating all my 3rd party plugs, will all those move over with migration assistant? I'm guessing I'll need to dump Waves licenses into The Cloud, but what about Pro Tools? Will I need to re-install that too or will migration assistant take care of it?
Old 02-27-2014, 01:20 PM
I have done plenty of work with Migration Assistant. I have found that it is useful for moving user home directories. It is not useful for moving anything that used an installer (i.e. Pro Tools 10) or anything that you dragged and dropped to somewhere other than /Applications.
Old 02-27-2014, 03:43 PM
Good to know, thanks for the info. I'm considering just updating through the app store rather than go through the whole process of wiping and restoring. Are there any known issues affecting Pro Tools with this method? I started over from scratch about a year ago so I wouldn't think there'd be too much extra junk in the past year, I waited about 7 years and 4 or so OS upgrades before wiping last time, granted I wasn't using Pro Tools for much of that.
?How to "clean uninstall" 10.3.5 to get to 11? werf Pro Tools 11 23 10-02-2013 07:35 PM
What exactly is a "clean uninstall" ? Johnny2Laps macOS 5 09-03-2013 01:54 PM
"Sticky" for Correct Uninstall-Reinstall Process for Pro Tools! RokVox macOS 28 09-26-2012 01:01 PM
Pro Tools 9 "Pausing" when I press "Play" with Focusrite Scarlett interface eanderso22304 macOS 3 11-23-2011 06:45 AM
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 danball macOS 2 09-26-2011 04:49 PM
