Old 09-22-2009, 04:02 PM
tonyridino tonyridino is offline
Default Error message when installing Pro tools LE 8 on windows XP..help!
Hi guys I just bought mbox mini and pro tools le 8. I can't seem to install it. I get this error about 13% into the installation process: (its a dialog box that pops up)
FEATURE TRANSFER ERROR
Feature Application files
Component: Session templates
File: D:\Protoo~6\data2.cab
Error: Data Error (cyclic redundancy check)
Then it either freezes my computer with a blue screen or goes back to the main installation page.
What's going on?
Im using windows XP on a dell, it's a few years old but I believe I meet all the guidelines. I'm installing it on my main system drive.
Old 09-22-2009, 04:12 PM
sunburst79 sunburst79 is offline
Default Re: Error message when installing Pro tools LE 8 on windows XP..help!
What's going on?
Usually the cyclic redundancy check error is the sign of a optical drive that needs its firmware updated or replaced.
Try copying the whole DVD to your desktop and run the installer from there. Normally this wont cause a blue screen though.
If you get PT installed after copying it to your local drive I would think about replacing the optical drive at some point when they go on sale.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 11-13-2009, 09:47 PM
dannyt18 dannyt18 is offline
I have been trying to install Pro Tool LE 8 with MBox 2 onto my Desktop Windows XP SP2. I keep getting the same error message of
Specs:
Microsoft Windows XP
Professional
Version 2002
Service Pack 2
1.00 GB Ram
AMD Athalon(tm) 64X2 Dual Core Processor 3800+ \ 2006.4 MHz
D: TSSTcorpCD/DVDW SH-S182M
Motherboard: abit NVIDIA nForce 570 Ultra KN9 Ultra
Video Card: NVIDIA GeForce 7600 GT
Feature Transfer Error
Component: Documentation - Control Surfaces
File: D:\protoo~6\data2.cab
Error: This request could not be performed because of an I/O device error
I also have been getting
Feature: Program Files
Component: Common
My last one is
Please any help will be great help iv been dying trying to figure out how to get it to work and i still haven't heard back from digi design about ways to fix it
Thanks so much for future help :)
Old 11-14-2009, 03:20 AM
sw rec sw rec is offline
dannyt18 should start his OWN thread with his OWN sandra report. The solutions are likely to be VERY different unless your hardware is exactly identical to that of the original poster.
Old 11-14-2009, 05:05 AM
Mekon Mekon is offline
Exactly the problem I saw with my PT LE 8 disc, bad data cab2 file. You'll have to get a download from Digi.
I tested the disc in a few different drives and PC's. The disc was bad, or the data cab2 file was corrupted on the disc.
Pro Tools 7 error message when loading to windows 7 akdz1982 Pro Tools M-Powered (Win) 1 02-12-2014 07:13 AM
Pro Tools 8 error message Windows 7 64 bit scshafer Windows 2 09-26-2013 08:27 PM
'Divide by zero' error after installing Pro Tools cs3 on Windows DigiTechSupt Technical Alerts 0 07-01-2009 10:18 AM
Error message pro tools 8 le windows xp PANTHA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-15-2009 05:55 PM
Pro Tools 6.4 and Windows XP Error message rseely 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-08-2004 08:57 AM
