easiest way to change tempo for midi trax??
hey all and happy holidaze!!
i'm lookin' for the easiest way to change tempo on midi trax recorded at a tempo that i've decided is too slow. this is what i know and have tried already... 1) edited the midi trax while in 'region' view. it worked but the pocket did not lock after the edits. now, i know it was my editing skills that were lackin' since i tried it more as a test then tryin' to be sample accurate but i feel like that method is definitely prone to error or just a lot of nudging and re-nudjing. 2) created a new session...created all new empty INST or MIDI trax with the grid set to my desired tempo...imported the desired trax into the region bin...dragged the imported midi trax into the new/empty trax and presto!! new trax at the right tempo BUT then i had to re-setup all the instruments and plugins (tho i did import the non-instrument plugins) 3) next method...created new session. set tempo to desired bpm. then did an 'import session data' from original session. worked like a charm, new trax created and ALL plugins imported BUT the tempo was the original tempo. and i did not import the tempo!!! while i did not expect the audio trax tempo to change, i did think the midi trax would be altered??!!! what am i missin'?? or is option 2 gonna be the way that's required??? PLS ADVISE!!! thanks...mykhal
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
Re: easiest way to change tempo for midi trax??
Make sure that the tracks Time-Base selector is showing Ticks and use the Add Tempo Change button.
filosofem
Aaron Mulqueen - 001 HD Native |
filosofem, thanks sooooo much!!! worked like a charm. man, that was easy!!!!
one other question...i actually took the original bass audio track from PT into LIVE and changed the tempo. then brought it back to PT. i know i could have used TC/E in PT but thought LIVE's time stretching was better??!! is there another method in PTLE 7.1 that you think is comparable to LIVE's quality with audio time stretching and compressing?? thanks again!!
Sorry, I can't really help you with that one, mykhal, I don't use Time Expansion/Compression plugs, personally I'd re-record the audio.
filosofem
yeah, will definitely re-record when production is at that point. but now, just in pre-production and building/writing/constructing the track. for me, easier and quicker to use the tools when tempo is the only issue. thanks again. you definitely helped me become more efficient. peace...mykhal
If that's the case, use Digidesign's TC/E or Serato's Pitch 'n Time. For a more professional usage try Waves Time Shifter.
filosofem
WAVES SOUNDSHIFTER (parametric plug-in) is slammin'!!! LIVE5 definitely has its' pluses but SOUNDSHIFTER gets my vote for ease of use, not to mention the quality of the output. great tool!!! thanks once again...mykhal
filosofem
Tempo change causing midi volume to change plugin output | tgrfox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-05-2011 01:08 PM |
Need to Change tempo but without changing existing midi data tempo? | Einsteinwannabe | Pro Tools M-Powered (Mac) | 2 | 09-18-2010 06:58 AM |
The best and easiest way to change loop tempo within pt7.1 | siga | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-10-2007 08:18 AM |
Midi Tempo Change | ape77 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-03-2006 06:33 PM |
midi and tempo change pt III | dubman | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-10-2005 03:18 PM |
