Re: Fader Module as MIDI controller suggestion.
HA!!!! Eddie's a Brit!!!! That explains a lot. Abbey Road consoles, Neve, Calrec, Trident, SSL and now the S6.
Dave Marsden UK |
I would personally wait until 2.2 to completely rebuild your Softkeys if that's what you are thinking of doing. We've added some new functions and new pages and EUCON is now aware of a lot more than it ever was including monitoring functions, S6 user preferences, Zone Banking, etc. As again, I would always recommend backing up your working ideas to XML files so you can pull from them if you had a particularly good idea.
best, Jeff |
@Eddie: How could I forget Raindirk!?
Dave Marsden UK |
#16
Sorry no date yet....at least a couple of months out
#17
If I rebuilt my softkeys now, will I be wasting my time and have to do it all over again when 2.2 comes out? Or could I incorporate the new functionality in 2.2 and adapt/edit whatever work I do now on my softkeys?..... (And keep saving those XML files of course!) I realise it will take longer if I do it now, for example, EUCON commands won't to get auto named etc.
Dave Marsden UK |
#18
You can do this now, the new commands in v2.2 can be added to your Appset later. The improvements we are making to the rest of the factory default Appset(like color coding) you could manually make to your custom one as well. It will just take you the time to do it and Jeff and I were worried that you would see the new v2.2 Appset and wish you had started from there. You can always see what's new and then replicate in your own Appset, again its just time there are no restrictions.
#19
In my opinion Softkeys are never done. You will probably realize that once you get your set "perfected" you will come up with some new ideas to better optimize your workflow. The best advice is to start tinkering and figuring out what is important to YOUR workflow and start placing functions where YOU want them. I guarantee that you will continue to tweak as we add new ideas and as EUCON starts to access new Pro Tools and monitoring functions. Create some different sets and save them. Go back to old ideas, etc. I'll try and post some out of the box ideas for customized Softkeys a little later this week so you can see the range of possibilities.
best, Jeff |
#20
Thanks guys, very much appreciated.
It sounds like I should start experimenting. I already have done to a degree. I'm guessing that the improvements to my workflow, (which is very much music composition/MIDI based,) by customising my softkeys will save me so much time it will easily offset any extra time I have to spend making adaptions and alterations for the new 2.2 functionality.
Dave Marsden UK |
MIDI Controller and Synth Module | Pete Seizure | Pro Tools 11 | 8 | 06-09-2015 10:52 AM |
XPand sound module & midi controller question | RichrdC | Pro Tools M-Powered (Win) | 7 | 04-13-2009 12:26 PM |
My Suggestion for Digi: 802.11 MIDI Controller | birdFEEDER | MIDI | 0 | 04-13-2005 10:29 AM |
Any suggestion on a Midi Controller for DIGI002 | Antonio Tarantino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-23-2003 12:29 AM |
use the controller keyboard as a tone module too, or just as controller? | Joseph Anderson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-08-2002 12:01 AM |
