My G5 has become really noisy
What rpm on the fans are normal on an average session with a few VI's?
Using Istat mine are most of the time around 3000 rpm. G5 dual 2.5 (liquid cooled) Just wondering... |
Re: My G5 has become really noisy
try changing the processor to Reduced in the Energy Saver System Pref.
While it's not ideal, it should quiet it down. |
Thanks Drew!
I'll try that. |
Pull the side cover off, and verify no coolant leak first.
My bet is that the G5 is being taxed to such a degree that its running hot enough to rev up the fans. Time for a new machine.
Thanks all
No leaking yet. I'm afraid she's dying (very slow). Hopefully she will last until digi shows their new HD system in january. Wishful thinking maybe I wont invest in current PCIe cards. BTW what rpm do your fans have under a little stress? |
I had one of these systems and while there was no visible signs of leakage, that's exactly what had happened...
Do yourself a favor and don't have it repaired.... get a new one. |
Sounds like you need a processor/fan calibration. I had my G5 done it's quiet now
Or.......you could try this....
Take the side panel off and the clear plastic bit. Pull out the two fans in front of the radiator grill (they just pull up together on a caddy) and check that the radiator grill isn't choked up with fluff or dust. If it is, whip out your hoover and give a good clean (use a paint brush to help shift any stubborn bits) This is exactly what happened to my G5dual2.5 and since then she's been as good as gold!! |
Yes, definitely open up and check for dust - I had similar problem and was shocked about the amount of dust in there - in fact, it wound up clogging the fan on my video card and fried it!
Noisy 192 IO (s) | Epik Productions | Pro Tools TDM Systems (Mac) | 25 | 05-31-2011 07:14 AM |
Just got my 11R, noisy... huh? | MyerzMedia | Eleven Rack | 14 | 03-27-2011 03:01 PM |
noisy noisy help please | cpoulin2000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-28-2006 03:36 PM |
Noisy Mac- Please help | Blindman13 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-03-2005 12:41 PM |
What to do with NOISY G4? | 5108 Music | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-24-2003 06:12 PM |
