Hardware Insert Delay Comp Issue
Ok, I have a 002 console. I am trying to measure latency for my hardware inserts.
Here is what I am doing: (delay comp on) I drew in a "pop" in an audio region with the pencil tool. I took a patch cable and routed it from output 5 on my 002 directly to input 5. Put IO 5 on an insert on the track with the "pop", routed that tracks output to a new audio track and hit record. Pro Tools 9 compensates automatically without me having to enter a value in the IO setup. With my buffer at 512 samples, PT reports 2142 samples of delay on the track with the insert. So now, the problem. When I do the same as above, but on my Apogee Ensemble which is hooked up via lightpipe to my 002, the "pop" is recorded 1ms early! The track reports the exact same delay as above. Are the Apogee converters just "faster"? Can I adjust this somehow? |
Re: Hardware Insert Delay Comp Issue
ADC does not compensate for 3rd party hardware delays. You can enter a value in the manual offset for ADC on the Mixer Window or enter a value in msecs in the I/O Setup.
Rail
Yes I know, but since the signal is "early", I would need to enter a negative value, right? This you cannot do.
Ah, I got it. I just entered the amount of samples that it was early the the +/- field on the track. Works perfectly now.
Still, the recording shouldn't be early, I've heard that it is a bug.
my blog:Tamas Dragon |
Imagine if you could record things before they happen. (Theme from Twilight Zone plays in background...)
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
Never thought this is a groundbreaking option. But now, you've changed my workflow!
all i know is that i enter 34 samples in the +/- field on the tracks with inserts going to my Ensemble and everything is dandy.
HW insert delay comp in PT11 (and OMNI question) | Tim R. | Pro Tools HDX & HD Native Systems (Mac) | 3 | 04-14-2013 01:54 PM |
Delay comp and buffer issue | pasanta | macOS | 6 | 02-02-2012 10:51 AM |
Delay Comp On Aux Issue | mattlange | macOS | 7 | 12-20-2010 09:19 AM |
Hardware Insert Delay value for 888/24??? | cronos | Pro Tools TDM Systems (Mac) | 3 | 01-29-2010 06:50 PM |
Hardware delay comp | blackbirdstudio | Pro Tools TDM Systems (Mac) | 1 | 01-03-2010 09:35 AM |
