Old 07-04-2008, 10:10 AM
therealprawphit therealprawphit is offline
Default Need help with Pro Tools 7.4 on Windows Vista Home Premium
When I open the cd and open the installation folder I cannot click on the setup without my computer slowing down significantly and not responding. Once I do get it open it takes forever then gives me an I/O device error. I tryed uninstalling and reinstalling the dvdr drivers and it still is happening.
SiSoftware Sandra
System
Host Name : HOME-0992EAE95A
User : Administrator
Workgroup : WORKGROUP
Processor
Model : Intel(R) Core(TM)2 CPU T7200 @ 2.00GHz
Speed : 2.00GHz
Cores per Processor : 2 Unit(s)
Threads per Core : 1 Unit(s)
Type : Mobile, Dual-Core
Internal Data Cache : 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 On-board Cache : 4MB, ECC, Synchronous, ATC, 16-way, 64 byte line size, 2 threads sharing
System
System : Dell Inc. MM061
Platform Compliance : Intel Centrino Mobile Technology
Mainboard : Dell Inc. 0XD720
Bus(es) : ISA X-Bus PCI PCIe IMB PCMCIA USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
System BIOS : Dell Inc. A15
Total Memory : 2GB DDR2
Chipset
Model : Dell 955XM/945GM/PM/GMS/940GML Express Processor to DRAM Controller
Front Side Bus Speed : 4x 166MHz (664MHz)
Memory Bus Speed : 4x 133MHz (532MHz)
Video System
Adapter : ATI Mobility Radeon X1400 (Microsoft Corporation - WDDM) (128MB, PCIe 1.00 x16, PS 3.0, VS 3.0)
Physical Storage Devices
SAMSUNG HM120JI 120GB (SATA150, NCQ, 8MB Cache) : 112GB (C:)
Seagate FreeAgentDesktop 250GB (USB) : 233GB (F:)
TSSTcorp DVD+-RW TS-L632D (ATAPI33, DVD+-RW, CD-RW, 2MB Cache) : 3GB (D:)
Logical Storage Devices
Hard Disk (C:) : 112GB (NTFS) @ SAMSUNG HM120JI 120GB (SATA150, NCQ, 8MB Cache)
FreeAgent Drive (F:) : 233GB (NTFS) @ Seagate FreeAgentDesktop 250GB (USB)
Pro Tools LE (D:) : 3GB (CDFS) @ TSSTcorp DVD+-RW TS-L632D (ATAPI33, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : Dell 82801GBM (ICH7-M) LPC Interface Controller
LPC Hub Controller 2 : Dell 82801G (ICH7 Family) SMBus Controller
LPC Legacy Controller 1 : SMSC LPC v1
Audio Device : Dell 82801G (ICH7 Family) High Definition Audio
Audio Codec : Sigmatel ??? (7690)
Audio Codec : Conexant Systems ??? (2BFA)
Serial Port(s) : 1
USB Controller 1 : Dell 82801G (ICH7 Family) USB Universal Host Controller
USB Controller 2 : Dell 82801G (ICH7 Family) USB Universal Host Controller
USB Controller 3 : Dell 82801G (ICH7 Family) USB Universal Host Controller
USB Controller 4 : Dell 82801G (ICH7 Family) USB Universal Host Controller
USB Controller 5 : Dell 82801G (ICH7 Family) USB 2.0 Enhanced Host Controller
FireWire/1394 Controller 1 : Dell R5C832 IEEE-1394 Controller
System SMBus Controller 1 : Intel 801xx/63xx SMBus
Printers and Faxes
Printer : Microsoft XPS Document Writer (600x600, Colour)
Network Services
Network Adapter : Broadcom 440x 10/100 Integrated Controller
Wireless Adapter 1 : Intel(R) PRO/Wireless 3945ABG Network Connection (802.11g (ERP), WEP n-bit, 54Mbps)
Power Management
Mains (AC) Line Status : On-Line
Battery No 1 : 100%
Operating System(s)
Windows System : Microsoft Windows Vista Home 6.00.6001 (Service Pack 1)
Platform Compliance : x86
Windows Experience Index
Current System : 3.7
Old 07-04-2008, 02:16 PM
rqstudio rqstudio is offline
Default Re: Need help with Pro Tools 7.4 on Windows Vista Home Premi
To my knowledge there are no 7.4 CD's for Vista. You''ll probably need to register your version with Digi and they'll send you an authorization to download 7.4 vista.
www.rickqueststudio.com
Old 07-04-2008, 02:23 PM
But on second glance, I'm not sure about your Platform Compliance : Intel Centrino Mobile Technology. Also there is a way to force XP compatibility but there is no need for that. Good Luck!
Old 07-04-2008, 11:10 PM
so i installed the program on my friends hp that also has windows vista home premium and it worked without any problems at all, im completely clueless I've done all the troubleshooting I can using google and finding similar instances I also failed to mention before that it's a Vista upgrade I was previously using XP Media Center
Old 07-05-2008, 09:09 AM
Then I guess you didn't read either of my post...
Old 07-05-2008, 12:02 PM
i did but that doesn't make sense that it would work on another vista laptop if there is compatibility issues
Old 07-22-2008, 09:08 AM
takuya takuya is offline
Default
I believe the Digidesign websites states that SP1 is not qualified. You can check it out here.
http://www.digidesign.com/index.cfm?...4&itemid=23876
Old 07-22-2008, 05:34 PM
The Weed's Avatar
The Weed The Weed is offline
Default
Pro Tools has been problematical with XP Media Center. By doing just the upgrade, that could be the issue. It is always better when installing a new OS to copy off the data you want to keep, format your OS drive and install the new OS as a clean install. Then update the OS and install your programs and copy back your data.
Cheers,
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 12-29-2008, 10:46 PM
acq1 acq1 is offline
Default Re: Need help with Pro Tools 7.4 on Windows Vista Home Premium
Cheers,
YUP!! I did the same thing. i had Media CEnter Edition. Tried just upgrading..Didn't work. i got every error under the sun. I just went in and did a fresh install, and have had no issues so far. There are conflicting drivers still on your harddrive. you need a clean install...
Mbox on Windows Vista Home Premium...? B Torres 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 06-02-2010 03:12 PM
pro tools 8 windows vista home premium???? bskipacoustic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-02-2010 03:01 PM
New Computer with Windows Premium Home Vista llubell General Discussion 2 04-06-2010 12:29 AM
Windows Vista Home Premium recordable drives DarthFader777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-25-2009 03:09 PM
Mbox 2 Mini & Windows Vista Home Premium. cliff_s 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 01-06-2008 10:00 AM
