Old 12-17-2015, 06:47 PM
banjo71 banjo71 is offline
Default error -9128
I just upgraded to Pro Tools 10.3.10 on Windows 7 OS, using the computer listed in the Sandra Lite description. I have a M-Audio Fast Track Pro interface hooked up USB. My audio storage is a Glyph device connected by firewire. Everything is working dandy except when I get this message:
You are running out of CPU power Remove some Native plug-ins or increase the CPU Usage Limit in the Playback Engine dialog. (-9128)
I watched my CPU meter when this happens, and it's not the CPU running out of power. I was probably using about 30% CPU usage when this happens. In any case, I wasn't using a bunch of plug-ins, and I was up to the 90% setting on the CPU Usage Limit.
Can someone tell me why I might be running into this?
SiSoftware Sandra
ID
Host Name : Doug-PC
Workgroup : WORKGROUP
Computer
Model : Dell Inspiron 560
Serial Number : 1Q8****
Chassis : Dell Desktop
Mainboard : Dell 018D1Y
Serial Number : ..CN7509*********
BIOS : Dell A04 07/02/2010
Total Memory : 8GB DIMM DDR2 DDR3
Processors
Processor : Pentium(R) Dual-Core CPU E5800 @ 3.20GHz (2C 3.19GHz, 2MB L2)
Socket/Slot : FC LGA775
Chipset
Memory Controller : Dell P45/P43/G45/G43 DRAM Controller 4x 200MHz (800MHz), 2x 4GB DIMM DDR2 DDR3 800MHz 128-bit
Memory Module(s)
Memory Module : Micron 8JTF25664AZ-1G4D1D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-34-10-5)
Video System
Monitor/Panel : ACR Acer V193W
(1440x900, 18.6")
Video Adapter : NVIDIA GeForce 210 (2CU 16SP SM4.1 1.24GHz, 1GB DDR3 1.2GHz 128-bit, PCIe 2.00 x16)
Graphics Processor
OpenCL GP Processor : NVIDIA GeForce 210 (16SP 2C 1.24GHz, 1GB DDR3 1.2GHz 128-bit)
Compute Shader Processor : NVIDIA GeForce 210 (16SP 2C 1.24GHz, 1GB DDR3 1.2GHz 128-bit)
CUDA GP Processor : NVIDIA GeForce 210 (16SP 2C 1.24GHz, 1GB DDR3 1.2GHz 64-bit)
Storage Devices
Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 466GB (C:)
Seagate ST1000DM003-1CH162 (1TB, FireWire/1394/SATA600, 3.5", 7200rpm) : 932GB (K:)
TOSHIBA TransMemory (4GB, USB2) : 4GB (F:)
Generic- SD/MMC (USB2) : N/A (G:)
Generic- Compact Flash (USB2) : N/A (H:)
Generic- SM/xD Picture (USB2) : N/A (I:)
Generic- MS/MS-Pro (USB2) : N/A (L:)
PLDS DVD+/-RW DH-16ABS (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:)
Logical Storage Devices
RECOVERY : 10GB (NTFS)
Glyph (K:) : 932GB (NTFS) @ Seagate ST1000DM003-1CH162 (1TB, FireWire/1394/SATA600, 3.5", 7200rpm)
Removable Drive (F:) : 4GB (FAT32) @ TOSHIBA TransMemory (4GB, USB2)
OS (C:) : 456GB (NTFS) @ Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache)
Removable Drive (G:) : N/A @ Generic- SD/MMC (USB2)
Removable Drive (H:) : N/A @ Generic- Compact Flash (USB2)
Removable Drive (I:) : N/A @ Generic- SM/xD Picture (USB2)
Removable Drive (L:) : N/A @ Generic- MS/MS-Pro (USB2)
Hard Disk (Q:) : N/A
Optical Drive (D:) : N/A @ PLDS DVD+/-RW DH-16ABS (SATA150, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : Dell LPC Interface Controller
LPC Legacy Controller 1 : ITE IT8720F
Audio Device : Dell HD Audio Controller
Audio Codec : Realtek Semi High Definition Audio
Audio Device : EVGA High Definition Audio Controller
Audio Codec : nVidia 000B
Disk Controller : Dell 6 port SATA AHCI Controller
USB Controller 1 : Dell USB UHCI Controller #4
USB Controller 2 : Dell USB UHCI Controller #5
USB Controller 3 : Dell USB EHCI Controller #2
USB Controller 4 : Dell USB UHCI Controller #1
USB Controller 5 : Dell USB UHCI Controller #2
USB Controller 6 : Dell USB UHCI Controller #3
USB Controller 7 : Dell USB EHCI Controller #1
FireWire/1394 Controller 1 : 13330 XIO2213A PCI Express to 1394b OHCI with 3-Port PHY
SMBus/i2c Controller 1 : Intel ICH SMBus
Printers and Faxes
Printer : Canon MG3200 series Printer (USB, Colour)
Scanners and Cameras
Scanner : Canon MG3200 series (Scanner, USB)
Peripherals
Media Player : Toshiba TransMemory (3.75GB)
Network Services
Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps)
Operating System
Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1)
Platform Compliance : x64
Windows Experience Index
Current System : 4.8
Pro Tools 12.6.1 for Windows 10
ASUS Core i7 3770
Yamaha Steinberg UR 44
Golden Age Project Pre-73 JR
Warm Audio WA12 MKII Preamp
Glyph 1TB GPT50 external drive - Firewire
LaCie 1TB external drive - USB
JBL LSR305 monitors
AT 2020 & 2021
Equation F.20 condenser mic
Old 12-17-2015, 09:32 PM
sw rec sw rec is offline
Default Re: error -9128
Firewire controllers are very finicky. What are you using? Ideally, a SIIG card with a TI chipset. If you're using onboard FireWire, that could very well be the problem.
Old 12-18-2015, 09:47 AM
Ya I'm using firewire through a card to my Glyph. Do you think an internal SATA drive would be good?
ASUS Core i7 3770
JBL LSR305 monitors
AT 2020 & 2021
Old 12-18-2015, 02:33 PM
Internal SATA drives will give the best performance
Old 12-18-2015, 06:46 PM
Got her figured out. With PT 8 I had a eSATA card for my Glyph, and it worked great. When I upgraded I must have knocked the card loose, and I assumed the card was no good, and I'd either have to try firewire or internal SATA. But I reinstalled the eSATA card and it's in place now. Works great.
ASUS Core i7 3770
JBL LSR305 monitors
AT 2020 & 2021
DAE ERROR 720/ also error (-9128):advice needed GeorgieC macOS 0 08-14-2012 03:32 AM
error -9128 Blackers Pro Tools 10 1 12-26-2011 06:45 PM
DAE error -9128 rtm Pro Tools TDM Systems (Win) 0 10-26-2009 03:33 PM
error -9092 & error -9128 problems zippitydoodah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-25-2007 08:04 AM
-9128 CPU error PlainJoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-22-2004 11:18 PM
