Old 12-10-2015, 06:11 AM
alidav alidav is offline
Default problem with elastic audio
Please, this is driving me crazy, no matter what i select, pt always give me this message, no elastic audio clips selected,
i tryied to make a pitch correction but rhythmic is the same,
is I select the whole clip I got the elastic property window otherwise not.
Old 12-17-2015, 10:15 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: problem with elastic audio
Hi, Try this - make your selection, then press Ctrl + E to make an edit at the in and out points. You should then be able to select the new clip and access the elastic properties.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 12-18-2015, 02:35 PM
Indeed^^^. 2 things to remember on this; #1-to fix a section, you need to first separate it, and #2-to make Elastic Pitch adjustments, you must use the Polyphonic algorithm.
Elastic audio problem alchemyy Pro Tools 10 5 02-14-2015 08:35 AM
elastic audio problem edwallace Pro Tools 10 1 03-01-2013 09:21 AM
Elastic audio problem??? mhender macOS 1 09-06-2012 02:15 PM
Elastic Audio problem clausiii Pro Tools M-Powered (Mac) 4 02-17-2010 02:26 AM
elastic audio problem Edson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 12-28-2007 01:40 PM
