Old 03-06-2011, 03:25 AM
miikkajk miikkajk is offline
Question Simultaneous recording with multiple midi channels
Hi!
First post, but yeah. I'm trying to record midi on 2 different midi channels, which are routed to 2 different instrument tracks. I'm using a Clavia Nord Electro 2 for the keyboards and Alesis DM5 e-drums for drums. The first midi cable goes from the nord's output to drums' input, nord uses channel 2 for it's midi, the drum is set for midi thru and it uses channel 1 for midi. The second cable goes from drums' output to ProFire 2626's input.
Everything else should be set, but Pro Tools itself won't let me set 2 different midi tracks to record at the same time. It would be helpful since I use the setup to jam and record songs with my friends; recording one at a time would spoil the mood and the very reason for jamming. Are there any track tricks to circuimvent this? The plugin instruments I use are Addictive Drums and Pro Tools' own Vacuum (for now), or any softsynths/soundbanks.
Thanks in advance! Even if it's just about saying it's impossible. At least I would know, heh.
Old 03-06-2011, 10:24 AM
HD2 HD2 is offline
Default Re: Simultaneous recording with multiple midi channels
Did you hold shift while you click on the record arm of the second track?
Old 03-10-2011, 07:28 AM
Shift did the job, thanks! (How could I be so simple...)
Old 07-17-2012, 10:44 PM
dovgee dovgee is offline
Wow thank you! Ive been looking around trying to find out how to do this and it was that bloody simple! :)
Simultaneosly Recording Multiple Channels 40hole5 Getting Started 3 10-30-2013 05:22 PM
No multiple MIDI files simultaneous playback SnowriderJ MIDI 3 10-17-2012 03:55 PM
Recording multiple midi drum channels to multiple audio tracks? ewan.mcghee MIDI 7 07-18-2011 01:46 PM
using mpc with pt and multiple midi channels lescorrea MIDI 5 07-27-2008 08:25 PM
Recording more than 8 simultaneous channels? scottyplayero 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 06-29-2003 03:16 PM
