How do I Export Separate Tracks?
Need to export to another studio.
Can't remember how to export separate tracks and can't find much via google. Want to export in sync to a data cd or a dvd? Use bounce to disk? hmmm...any help? thanks |
Re: How do I Export Separate Tracks?
One method is to consolidate the tracks so they all start at zero, then export the regions from the region bin menu. No need to bounce unless you need to apply effects or have a mix etc...
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R |
So for a walk through.....? Also my 'export' under file is ghosted out
I'm not in front of my DAW, but this is how I remember it:
1) Highlight the entire track Go to Edit>Consolidate 2) Take note of the newly named / conslidated region (e.g. Guitar_01.wav) 3) Go into your session audio files and copy / paste them to a thumb drive. 4) Take your thumb drive to Studio B and you're good to go. Or, you can use "Import Session Data." That is a little more complicated, but Google that phrase and you'll find plenty of info.
PC: Dell Studio XPS 9000 Hardware: 002r, Mbox 2, Digimax D8, ART Pro MPA II (w/ Mullard Tubes) Guitarist | Singer | Songwriter | Engineer www.stolenalibi.com |
record it into a new audio track and consildate it!!!!
and to add the MIDI tracks:
file>export>MIDI? |
MIDI - yep. I'm not in front of PT either, but IIRC you get asked to export to a single track (Type 0) or multitrack (Type 1) MIDI format. Just export it, & save it to your usb stick along with your audio, then re-import at the other studio.
When you import you'll get the option to import to new track(s) or just to the region bin. Oh, and as for the click; if you import session data there is the option to copy the tempo map from the session you're importing from. If you're just taking the audio files then as S.w.A.t. suggests, just bus it out to an audio track, record it then treat it the same as the other audio files. Personally, if you have a tempo mapped out with a few changes, I'd prefer to have that tempo map & dedicated click track when I'm working on it in the other studio, so I'd take the session & import it as session data. All depends what you're going to be doing at the other end I guess.
Chaz Shifting Sands Audio www.shiftingsandsaudio.com soundcloud.com/shiftingsands Asus X79 Deluxe | i7 4930K @ 4.1 | 32Gb Ripjaws CL9 GBLZ | Radeon R5 230 | Win7 Pro (64) | 256Gb Samsung 850 SSD | 2x 1Tb Seagate SATA | 250Gb Samsung EVO SSD | 128 Samsung SSD | Antec 650W | ProTools 11.3.2HD, 10.3.9HD, 12.5 | Cubase 9.0.20 Pro | Nuendo 8 | Studio One 3.2 Pro | RME UFX | 2x Octopre Mkii Dynamic | Alphatrack | DTouch | Logitech G510 | Kensington Trackball | Yamaha UX256
How about exporting my mixes too?
Pro Tools 6.4 how to export separate tracks in .Aiff ? | Bornathe | Pro Tools 9 | 2 | 01-11-2014 10:59 AM |
How can I "batch" export each region as separate audio file? | Screenery | Tips & Tricks | 1 | 05-03-2008 10:12 PM |
Using Reason on separate tracks | tunecrab | Pro Tools M-Powered (Win) | 1 | 06-07-2007 07:51 PM |
how do I export separate LE tracks to Cubase SX? | lonestarparis | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-08-2006 09:44 AM |
How to separate tracks | fredbeg | Digidesign Hardware & Software | 3 | 07-23-2001 03:32 AM |
