Old 08-29-2009, 11:53 PM
Jeff E Jeff E is offline
Default Send Mutes to Follow Channel Mutes
Here is where I want to end up..
I want my sends to be in Pre Fader so that the levels are not effected by the Channel fader. But I want my Mutes to be in post Fader so that when I mute the channel the send mutes as well. Can I do this some how? Is there a magic box to click some where?
My set up is that I am using a send to go to my Ferman headphone system and need to be able to mute certain channels but they need to be pre fader when it comes to levels.
Thanks..
Jeff
Old 08-30-2009, 02:15 AM
Ru_C Ru_C is offline
Default Re: Send Mutes to Follow Channel Mutes
Thanks..
Jeff
Hi Jeff, yeah i've wondered about this one myself, but never found a way.
A couple of questions...
* Are you using PT with a control surface &/or a monitor controller (presonus central station or suchlike)?
* why do you need to this in your workflow?
I ask, as i've done some fairly complex monitor setups recently, & there can often be a solution with a bit of lateral thinking..
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2023.6 Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES
B Rig: (Home/Office). M1 Mac Studio - 64gb ram - OSX 12.7.1, PT Ultimate2023.6, HD Native Thunderbolt, Omni, Avid Artist Control
http://www.lostboysstudio.com
Old 08-30-2009, 06:55 PM
Ru_C
Yes we are using the Euphonix control system and it works great. I have not thought about using that in this yet to get this to happen. We are using the Presonus central station for monitor levels and switching - it also works great.
We are using the Furman HDS-16 system which also works wonderfully.. So much more robust than the Hear system over all. we use the talk back on the Hrm-16 boxes for talk back in the control room which is great as a work around for going mixer-less.
AS far as work flow. We have a template set up in PT 8 that has all the 8 sends to the Furman system. We usually do a stereo mix of the drums and then allow every one else to build up the rest how they want.
When we are tracking something like BGV and we build one track at a time there are times when we want one track muted as in someone doubling a vocal part. So as that track has a send to the head phone mix just muting the channel does not remove it from the send. So it is still playing in the head phone mix but not in the control room - sometimes to our embarrassment. :)
So, yes we can mute one at a time but it would be much easier to mute just the one.
Thanks
Jeff E
Old 08-30-2009, 08:08 PM
Carl Kolchak Carl Kolchak is offline
The two ways that spring to my mind are as follows:
1. When you hit mute, remember to also bypass the send for that channel (this requires two button pushes / mouse clicks).
2. Set up intermediate Aux channels that are grouped with you audio tracks, so that when the original track is muted it kills the feed from the intermediate Aux to the headphone amp (this only requires one button push / mouse click, but could end up using a ton of resources).
Food for thought.
Old 08-30-2009, 10:00 PM
Danny Caccavo Danny Caccavo is offline
Funny how some of us grew up with consoles where the channel mute would mute the pre-fader send and some of us didn't.....I always wanted to have the option for the former in Pro Tools....
-Danny
Old 08-31-2009, 12:15 AM
-Danny
Thats exactly waht my partner said..
Old 08-31-2009, 12:18 AM
Food for thought.
Thanks Carl,
The resources thing is the issue.. we cold switch back to the tracking mix but it messes with all the DSP and all .. and its a pain..
Old 08-31-2009, 01:46 AM
tj_davies tj_davies is offline
Food for thought.
3. Instead of muting, deactivate the track.
Timothy
Mac Studio Ventura 13.6
PT 2020.12.0
www.pearls-music.com
Old 08-31-2009, 08:05 AM
Ru_C
Thanks
Jeff E
Yes, i feel your pain !
One solution, does your control surface have a 'send to faders' feature like the procontrol does?
If so, you could
1) Route the stereo output of the furman unit *back* to the TRS2 input of your Central station. This would give you a quick way of monitoring what the artist is hearing, without messing up your main mix.
2) Flip the appropriate 'send to faders' on your control surface. Now pressing 'mute' on a track should mute the send. You can flip between hearing the control room & artist mix by selecting TRS1 or TRS2 on your central station remote.
Alternatively
1) set the BV tracks being recorded to post-fader send, & set the main fader level at unity/0Db, but set the output to 'No Output'
2) create a post-fader send on these tracks that goes to an AUX called BV's, this send will be the control room volume control.
Use this Aux to monitor what is being recorded on the BV tracks. Muting any BV track will mute them to the BV AUX too.
More food for thought, along with the other suggestions.
Linking channel mutes TheMAXX7 VENUE Live Sound Systems 9 02-11-2012 03:50 PM
Touch beside the fader mutes the channel... webstereo ICON & C|24 2 08-24-2010 07:02 AM
Is there a way to link track mutes to send mutes? Ed Douglas Tips & Tricks 6 01-05-2010 06:39 PM
Automate multiple aux send mutes? moblues 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-12-2004 10:32 PM
sends follow mutes sla Pro Tools TDM Systems (Mac) 7 12-18-2003 01:21 PM
