Volume automation: Changing overall level??
I have a vocal track with volume automation. How do I increase and/or decrease the overall level a few DB without changing any of the automation movements? This is obviously for having several mixes with vocals up and/or down. Thanks in advance, Jason
P4 3.2,ABIT IC7,875P chipset,512 Ram,Digi 002,LE 6.7 www.jasonwhinnery.com [email protected] |
Re: Volume automation: Changing overall level??
In Volume mode, you use the Trimmer ([) tool
From the manual. "The Trimmer lets you adjust all selected breakpoints up or down by dragging anywhere within that selection." You can select any number (including all points) and move those automation points up or down. Is is a lifesaver!
5198 Studios |
Thanks so much for the quick reply. That's just what I was looking for. Jason
Or a real easy way is to put the trim plug-in on the track and adjust the level with that. It gives you level adjustment and the volume automation of the track stays the same.
https://www.thirdeyerecording.com/ |
all the way up and that will give you more of a gain, but you probalby wouldn't need that much gain for what your trying to do
www.klarityrecordingstudios.com |
Thanks for all the advice.
Jason
Changing a mic level signal into a guitar level signal with correct impedance | mgnyhc1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 09-22-2009 11:15 AM |
Volume level automation while recording | Davidm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-14-2005 07:59 PM |
Edit Volume Level of a region without automation | markus44uk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-12-2005 05:04 AM |
changing volume of automation envelope as a whole | wolffy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-26-2004 10:25 AM |
changing volume automation | lcouri | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-28-2001 10:36 PM |
