error -9128
I just upgraded to Pro Tools 10.3.10 on Windows 7 OS, using the computer listed in the Sandra Lite description. I have a M-Audio Fast Track Pro interface hooked up USB. My audio storage is a Glyph device connected by firewire. Everything is working dandy except when I get this message:
You are running out of CPU power Remove some Native plug-ins or increase the CPU Usage Limit in the Playback Engine dialog. (-9128) I watched my CPU meter when this happens, and it's not the CPU running out of power. I was probably using about 30% CPU usage when this happens. In any case, I wasn't using a bunch of plug-ins, and I was up to the 90% setting on the CPU Usage Limit. Can someone tell me why I might be running into this? SiSoftware Sandra ID Host Name : Doug-PC Workgroup : WORKGROUP Computer Model : Dell Inspiron 560 Serial Number : 1Q8**** Chassis : Dell Desktop Mainboard : Dell 018D1Y Serial Number : ..CN7509********* BIOS : Dell A04 07/02/2010 Total Memory : 8GB DIMM DDR2 DDR3 Processors Processor : Pentium(R) Dual-Core CPU E5800 @ 3.20GHz (2C 3.19GHz, 2MB L2) Socket/Slot : FC LGA775 Chipset Memory Controller : Dell P45/P43/G45/G43 DRAM Controller 4x 200MHz (800MHz), 2x 4GB DIMM DDR2 DDR3 800MHz 128-bit Memory Module(s) Memory Module : Micron 8JTF25664AZ-1G4D1D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-34-10-5) Memory Module : Micron 8JTF25664AZ-1G4D1D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-34-10-5) Memory Module : Micron 8JTF25664AZ-1G4D1D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-34-10-5) Memory Module : Micron 8JTF25664AZ-1G4D1D 2GB DIMM DDR3 PC3-12800U DDR3-1600 (9-9-9-25 4-34-10-5) Video System Monitor/Panel : ACR Acer V193W (1440x900, 18.6") Video Adapter : NVIDIA GeForce 210 (2CU 16SP SM4.1 1.24GHz, 1GB DDR3 1.2GHz 128-bit, PCIe 2.00 x16) Graphics Processor OpenCL GP Processor : NVIDIA GeForce 210 (16SP 2C 1.24GHz, 1GB DDR3 1.2GHz 128-bit) Compute Shader Processor : NVIDIA GeForce 210 (16SP 2C 1.24GHz, 1GB DDR3 1.2GHz 128-bit) CUDA GP Processor : NVIDIA GeForce 210 (16SP 2C 1.24GHz, 1GB DDR3 1.2GHz 64-bit) Storage Devices Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) : 466GB (C:) Seagate ST1000DM003-1CH162 (1TB, FireWire/1394/SATA600, 3.5", 7200rpm) : 932GB (K:) TOSHIBA TransMemory (4GB, USB2) : 4GB (F:) Generic- SD/MMC (USB2) : N/A (G:) Generic- Compact Flash (USB2) : N/A (H:) Generic- SM/xD Picture (USB2) : N/A (I:) Generic- MS/MS-Pro (USB2) : N/A (L:) PLDS DVD+/-RW DH-16ABS (SATA150, DVD+-RW, CD-RW, 2MB Cache) : N/A (D:) Logical Storage Devices RECOVERY : 10GB (NTFS) Glyph (K:) : 932GB (NTFS) @ Seagate ST1000DM003-1CH162 (1TB, FireWire/1394/SATA600, 3.5", 7200rpm) Removable Drive (F:) : 4GB (FAT32) @ TOSHIBA TransMemory (4GB, USB2) OS (C:) : 456GB (NTFS) @ Seagate ST3500418AS (500.1GB, SATA300, 3.5", 7200rpm, 16MB Cache) Removable Drive (G:) : N/A @ Generic- SD/MMC (USB2) Removable Drive (H:) : N/A @ Generic- Compact Flash (USB2) Removable Drive (I:) : N/A @ Generic- SM/xD Picture (USB2) Removable Drive (L:) : N/A @ Generic- MS/MS-Pro (USB2) Hard Disk (Q:) : N/A Optical Drive (D:) : N/A @ PLDS DVD+/-RW DH-16ABS (SATA150, DVD+-RW, CD-RW, 2MB Cache) Peripherals LPC Hub Controller 1 : Dell LPC Interface Controller LPC Legacy Controller 1 : ITE IT8720F Audio Device : Dell HD Audio Controller Audio Codec : Realtek Semi High Definition Audio Audio Device : EVGA High Definition Audio Controller Audio Codec : nVidia 000B Audio Codec : nVidia 000B Audio Codec : nVidia 000B Disk Controller : Dell 6 port SATA AHCI Controller USB Controller 1 : Dell USB UHCI Controller #4 USB Controller 2 : Dell USB UHCI Controller #5 USB Controller 3 : Dell USB EHCI Controller #2 USB Controller 4 : Dell USB UHCI Controller #1 USB Controller 5 : Dell USB UHCI Controller #2 USB Controller 6 : Dell USB UHCI Controller #3 USB Controller 7 : Dell USB EHCI Controller #1 FireWire/1394 Controller 1 : 13330 XIO2213A PCI Express to 1394b OHCI with 3-Port PHY SMBus/i2c Controller 1 : Intel ICH SMBus Printers and Faxes Printer : Canon MG3200 series Printer (USB, Colour) Scanners and Cameras Scanner : Canon MG3200 series (Scanner, USB) Peripherals Media Player : Toshiba TransMemory (3.75GB) Network Services Network Adapter : Realtek PCIe GBE Family Controller (Ethernet, 100Mbps) Operating System Windows System : Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance : x64 Windows Experience Index Current System : 4.8
Pro Tools 12.6.1 for Windows 10 ASUS Core i7 3770 Yamaha Steinberg UR 44 Golden Age Project Pre-73 JR Warm Audio WA12 MKII Preamp Glyph 1TB GPT50 external drive - Firewire LaCie 1TB external drive - USB JBL LSR305 monitors AT 2020 & 2021 Equation F.20 condenser mic Last edited by banjo71; 12-17-2015 at 07:03 PM. |
Re: error -9128
Firewire controllers are very finicky. What are you using? Ideally, a SIIG card with a TI chipset. If you're using onboard FireWire, that could very well be the problem.
Re: error -9128
Ya I'm using firewire through a card to my Glyph. Do you think an internal SATA drive would be good?
Pro Tools 12.6.1 for Windows 10 ASUS Core i7 3770 Yamaha Steinberg UR 44 Golden Age Project Pre-73 JR Warm Audio WA12 MKII Preamp Glyph 1TB GPT50 external drive - Firewire LaCie 1TB external drive - USB JBL LSR305 monitors AT 2020 & 2021 Equation F.20 condenser mic |
Re: error -9128
Internal SATA drives will give the best performance
Re: error -9128
Got her figured out. With PT 8 I had a eSATA card for my Glyph, and it worked great. When I upgraded I must have knocked the card loose, and I assumed the card was no good, and I'd either have to try firewire or internal SATA. But I reinstalled the eSATA card and it's in place now. Works great.
DAE ERROR 720/ also error (-9128):advice needed | GeorgieC | macOS | 0 | 08-14-2012 03:32 AM |
error -9128 | Blackers | Pro Tools 10 | 1 | 12-26-2011 06:45 PM |
DAE error -9128 | rtm | Pro Tools TDM Systems (Win) | 0 | 10-26-2009 03:33 PM |
error -9092 & error -9128 problems | zippitydoodah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 07-25-2007 08:04 AM |
-9128 CPU error | PlainJoe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-22-2004 11:18 PM |
