Go Back   Avid Pro Audio Community > Legacy Products > Digidesign Hardware & Software
  #21
Old 10-28-2008, 06:34 AM
Carbon Filter Carbon Filter is offline
Default Re: Adding another 888/24 to mix plus system
Originally Posted by John_Toolbox View Post
Hold down Shift-Apple-3 simultaneously, it will take a screenshot of the entire desktop.
Shift-Apple-4 will take a screenshot of a boxed area you determine by clicking and dragging.
Thanks for the info John, I will give it a shot.
Best Regards,
David Arnold
www.stumpsound.com
  #22
Old 12-02-2008, 01:14 PM
Originally Posted by DigiTechSupt View Post
Are you turning on the interfaces first, before booting up the computer?
If you do an 'identify' in the hardware setup dialog (when the units first work), does it identify the proper interface?
Could you possibly post a screenshot of your hardware setup window, so we can see if something there may clue us in to what's going wrong?
I have finally got sometime put aside to try to attempt to hook this second 888/24 I/O this upcoming weekend. I will take a screen shot to see if I am missing something. Like I said in my previous posts its the fact that once the second interface is hooked up (with approved brand new Y cable direct digidesign) on start up the 888/24 interface "ANALOG" metering stays flashing all the way even when the desktop loads which means it remains in standalone mode. Therefore Pro Tools will not lauch. Only having 1 888/24 hooked this system has been rock solid for 8 years! Its a back up system I would dearly like to get running with full 16 ins just in case. I will keep you guys up to date
Thanks
  #23
Old 12-23-2008, 07:11 AM
A lot of trouble shooting has happened in the past couple of weeks with trying to expand this back up mix plus system of mine. If anyone is trying to expand there old mix plus systems with additional interfaces...i might be of some help. At least I will do my best. Just PM me or shoot me an email.
Thanks,
  #24
Old 12-23-2008, 01:23 PM
milesofwire milesofwire is offline
I always turn my interface(s) on AFTER I turn on the computer, otherwise they will go into standalone mode....
  #25
Old 12-24-2008, 06:45 AM
FajitaTone FajitaTone is offline
here's a stupid question... is the second interface connected to Mix card 1, 9-16 in Hardware setup?
Ray Trujillo
Freelance Audio Engineer
  #26
Old 12-24-2008, 09:07 AM
Yes all of that is set up
  #27
Old 12-24-2008, 09:10 AM
honestly have never tried that.... but most of all these system i have used in the past have always worked by standard digi protocol start up which is scsci first, interface 1 , then interface 2 then computer. But I will give that a shot just to see what happens. I narrowed down the issue with this particular system but like i said this is just a back up system ...
HTML code is On
OT: Adding UAD-2 RTAS to HD system. lownotesinc Pro Tools TDM Systems (Mac) 1 10-19-2011 12:25 AM
Adding a second LE system to Venue MikeTrahearn VENUE Live Sound Systems 2 12-06-2008 10:31 AM
Adding MIX cards to PT System byronfunk Pro Tools TDM Systems (Mac) 1 05-29-2007 10:18 AM
Adding ram to DIGI 001 system jcress 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-04-2004 07:24 AM
Adding a PCI Graphics Card to PT HD2 System Stacey Pro Tools TDM Systems (Mac) 1 04-23-2003 02:05 AM
