Record in 16 Bit or 24 Bit?
Should I be recording in 16 bit or 24 bit? I know 24 Bit is the higher digital quality but I have heard that Pro Tools sometimes has problems with the 24-Bit and that most audio devices such as stereos and cd players are only 16 Bit anywayz. Has anybody had any problems with the 24 Bit setting?
Re: Record in 16 Bit or 24 Bit?
I've had problems. Media player won't play the bounced tracks. Makes you wonder, why do the music programs already allow 24bit recording when not much if anything can handle it? I mean, obviously the music programs themselves can handle it... Who wants to buy Pro Tools just to listen to a song?
Kryst |
please record in 24 bit / 44.1 ! when you bounce down, simply insert a dither plug-in at the end on the master fader, such as the Digidesign POWr, and select 16-bit as your destination file. WAV, WMA, MP3, etc. with storage being so cheap 16-bit digital recording shouldn't even be an option in DAW land. to put it simply, the reason DAWs allow you to record at 24 bit is because it sounds better. even though you're converting to 16-bit at the end of the process, it sounds better. take care |
For even more "depth & clarity" record at 24/96 kHz....HUGE DIFFERENCE!!!
rockrev
End world poverty: ONE |
what rockrev said.
for CD purposes... and especially if you're going straight to MP3/internet/micepace 24 / 44.1 is the ticket |
If your final destination is a CD (16-bit 44.1k) and you must use a higher sample rate with LE, I would go with 88.2k as the math is smoother and therefore less problematic when converting down to 44.1k.
Thanks for all the help...I'll have to start recording in 24 Bit and then exporting 16 bit...appreciate it.
i realy cant believe some people still stick to 16 there is no point unless you want your recording to sound thin
im fully guessing this but i recon
its like if u r editing a photo u wanna work in highest res and format posibble u dont do all your editing on a JPG low res cuz when u add effects or resize and so forth it would look total crap u only make the final product a JPG low res cuz ur done wit it i mean it dpened also where the final product gona b seen if its a small image on a webpage jpg is cool if its going on a 1000foot billboard u gona need higher format cds r chimp quality man dats 16/44 u no wot i meen? peace d d |
Session must be on an audio record volume if permmited set the volumes to R record | lionandthemouse | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-11-2013 01:48 PM |
Record 1 audio track, then go to record a second, the timer button flashes... help | tdubthatsme | General Discussion | 5 | 02-27-2011 04:39 PM |
MIDI record enabled and found but wont record | BCRich | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-23-2010 12:51 PM |
Press Arm Record then Play and have to wait 3 miniutes before record/playback starts | The Muphin Man | Pro Tools SE and Essential (Win) | 8 | 09-10-2010 07:03 PM |
Crackling in record mode (even when not actually recording), cannot record > 10 secs | chandra | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 08-16-2010 09:08 PM |
