Reason Drum Kit with Reason Adapted?
Or do I have to upgrade to Reason 3?? Can I assign each drum part to a separate PTLE track??
Thanks SB |
Re: Reason Drum Kit with Reason Adapted?
Yes you can. Just create a mono instance of reason for every drum track you want(say 10 for a redrum) and make the output for each channel count up from channel 1 to channel 10.(I think that's right? ) Then in Reason manually patch the outputs for each redrum channel to the first 10 output channel on the main interface in Reason(it has 64 channels). Set up your kits and go to town.
I hope that's right, I'm not at my PT box.
Intel I7 920 Asus P6T Digi 002R. Command/8 PTLE 7.1 MPT www.clearspotrecording.com |
You can't load the reason drum kit refill into adapted. It requires the NN-XT sampler, which is only in the full version.
Not true. You have to use the MONO version of the adapted rewire to output separate channels.
See here? ~
Are you using the mono, the multi-mono, or the stereo version of the plugin?
Reason Adapted can only use the included, slimmed-down sound bank - it will not load anything from other ReFills (ie RDK). So you will have to purchase a full version of Reason in order to use RDK.
...and it's totally worth it because the full version of Reason is amazing...and the Drum Kits are... "WOW" kind of good. |
Great Price - Reason Adapted To Reason 4 - $239 / EUR 199 | BPlayer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-17-2007 10:05 AM |
recording drum loops on reason adapted | sbond | Virtual Instruments | 5 | 01-18-2007 06:53 PM |
Drum programming in Reason Adapted: Does anyone? | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-08-2006 12:00 PM |
Reason Adapted and Drum Refill packs | Craig F | General Discussion | 1 | 02-06-2006 07:15 PM |
Upgrade PT Reason Adapted to FULL Reason ...Price? | bluesigns | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-09-2003 07:04 AM |
