Old 11-05-2004, 12:30 PM
DigiTone DigiTone is offline
Default Asus MOBO - what\'s the secret
I'm "running" an 02R on a machine with an Asus A7N8...(something) motherboard. After FAR too much messing around with it, LE generally runs, with one big problem:
=> using any of the keyboard keys during playback often causes it to stop playing and complain about holding off interrupts too long. In extreme cases, it prevents me from starting playback by using the spacebar.
Running Win XP (SP1). There's plenty of memory. Most all functions not required for audio work are turned off. Small number of tracks (<8), small number of plug-ins.
I think people are sucessfully using set-ups very like this. There must be a solution, right?
Don't get me started about non-real-time bounces...
Old 11-05-2004, 12:38 PM
bigbubbaj bigbubbaj is offline
Default Re: Asus MOBO - what\'s the secret
I have the a7n8x-deluxe.
you have to get an add-on firewire card. I have the adaptec 4300.
getting the fw card, and a oxford 911 chipset FW hard drive cured all of my problems.
I have the onboard FW also, and PTLE runs really poorly on it.
5198 Studios
Old 11-05-2004, 02:35 PM
CozmoXP CozmoXP is offline
I have the A7N8X deluxe and had some issues as well. I picked up the SIIG 3 port PCI card and the problems went away.
AthlonXP 2700+, 1.5GB XMS DDR,A7N8X Dlx,120g 8mb Seagate System drive, 160g 8mb SATA recording drive, dual 19" CRTs and an 002r on XPSP2!
Old 11-05-2004, 05:21 PM
OK, thanks. Just to make it this far, I had to put in a firewire card. Maybe I got cheap one and that's the difference between working and working great.
Old 11-05-2004, 08:50 PM
Chipsets do seem to matter. FWIW, The Adaptec 4300 with this MOBO seems to be a great combo. I had a cheap one, and returned it to get the 4300. Best Buy carries is for about $35-$40.
I am assuming you have an AGP video card? A pci card would put an lot of strain on the PCI bus which seems to cause PTLE problems.
5198 Studios
Old 11-05-2004, 08:59 PM
Captain_Pants Captain_Pants is offline
Do they even make PCI vid cards anymore?
Ill suffer winter alone;
ten thousand miles from home...
Old 11-05-2004, 09:11 PM
I have one that i used to use as a second monitor. Had a ton of PTLE problems with it. ended up getting the Matrox p650. The p650, the 4300 and the FW hard drive. No PTLE problems anymore.
5198 Studios
Old 01-27-2006, 01:09 PM
OK, a year later, I stumble on it. The Firewire card is sharing an interrupt with the keyboard, hence the contention. By moving the firewire card to another PCI slot, (swap it with the SCSI card), the FW card gets assigned a different interrupt. Problem solved.
No excuse for this sort of sillyness. Ever.
D
Please Help Re: the Asus P5wdg2 ws pro mobo Abdullah 1234 Pro Tools TDM Systems (Win) 7 07-04-2008 05:18 PM
Asus P5B Mobo powerjoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-01-2007 11:21 PM
Asus A8V MOBO? Dayliner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-29-2004 03:39 PM
001, WIN XP, ASUS A7V333 MoBo Erik Galindo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-22-2003 10:13 PM
ASUS MoBo bassist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-14-2003 12:05 AM
