Old 05-12-2023, 05:57 AM
Cryos's Avatar
Cryos Cryos is offline
Default Quick Question regarding Control app
I just purchased 2 x S1 controllers. Their all linked up and working fine however when I go into the softkeys page I only see ONE S1 item under the pull down menu which is strictly for the bottom buttons on the surface. I do see 3 or 4 items available for the S3.
So question is; is this normal or has Eucontrol some how glitched out?
Otherwise everything seems to work seamlessly . At one point one of the surfaces fader wasn't doing anything on the brand new unit and I was worried it was defective, I turned off the power and powered it up again and everything was fine.
Cheers
Cory Rizos, CAS
Re-recording Mixer/Sound Designer
Montreal, Quebec
http://www.imdb.com/name/nm0007185/
coryrizos.com
Old 05-12-2023, 06:54 AM
smurfyou smurfyou is offline
Default Re: Quick Question regarding Control app
Are you on the newest Eucon release? You should see both as they can have independent soft keys now.
~Will
Old 05-12-2023, 11:27 AM
Cryos's Avatar
I am actually on the last version of the software . I'm not clear on your explanation. The only thing I see regarding the S1 in the softkeys pull down menu is a single instance of the S1 which allows you to modify the 8 hardware colour keys at the bottom of the units. There's nothing else available.. As foe the S3 like I said there's at least 3 items in the pull-down menu.
Cory Rizos, CAS
Montreal, Quebec
coryrizos.com
Old 05-12-2023, 11:41 AM
I meant if you have two S1's they should each show up. But I'm sorry I don't know how to rectify.
~Will
Old 05-12-2023, 11:54 AM
its2loud its2loud is offline
if you're running the latest version of Eucon you'll see a drop down menu underneath "section" where you choose S1 Color Keys for the S1 Unit.
See the pic.
File Type: jpg Screen Shot 2023-05-12 at 11.52.24 AM.jpg (34.4 KB, 0 views)
Old 05-12-2023, 01:17 PM
Cryos's Avatar
Yeah. That's all I see. Ok so it's normal that's the only thing that's available ..cool.
Everything else works spotlessly . Nice having 2 S1!
Cory Rizos, CAS
Montreal, Quebec
coryrizos.com
Old 05-12-2023, 02:11 PM
Glad you're seeing that on your end. I'm a bit confused. What were you expecting to see available in the drop down menu?
Old 05-13-2023, 11:16 AM
EddieJones's Avatar
Hit the Plus sign to add another S1
Old 05-18-2023, 04:32 PM
Cryos's Avatar
I thought I'd see a whole nunch of pages to program custom buttons anywhere on the surface. It's all good! Units are great!
Cory Rizos, CAS
Montreal, Quebec
coryrizos.com
Pro Tools 9 + Mackie Control Universal " Jog wheel " .... very quick question ? ben ifin Pro Tools 9 12 08-28-2017 05:07 PM
MC control quick question FilterDecay Artist Series 2 12-06-2011 09:50 AM
Quick quick quick DSP farm card Question Mr335 Pro Tools TDM Systems (Mac) 1 12-06-2002 07:37 AM
* SPEED plugin - quick question on pitch control peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-30-2002 11:05 AM
A quick question for any Logic Control users... redleader 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-22-2002 10:11 AM
