Old 05-01-2023, 11:38 PM
shupp shupp is offline
Default Avid Control Monitoring w/ Apollo x6?
Hey folks,
I'm a pretty new with using Avid Control, but I have Pro Tools Studio, an Avid S1 + iPad w/ Avid Control, a UAD Apollo x6, and a 5.1 Surround setup for use on post production. Right now, I can only manage my monitors through the UAD Console app for muting/soloing speakers. I'm interested in doing this through Avid Control, but it currently shows "none" when trying to select a source. Does anyone know if I can do this through Avid Control? And if so, perhaps perhaps point me to any docs to help me get it configured?
Thanks very much!
Bill
Old 05-02-2023, 12:31 AM
Default Re: Avid Control Monitoring w/ Apollo x6?
AFAIK UAD Console does not directly support any control surfaces. Even after UAD added control surface support in Luna I still don't think they added it to Console.
There is third party software that enables MCU control of Console. https://www.raduvarga.com/software/ua-midi-control
Presumably you can put what you have in MCU compatibility mode and control the Console that way. But who knows... maybe you'll get lucky here and find somebody doing that. If not experiment...
You could try suggesting to UAD they support EUCON in Console and Luna. But I suspect that would get you exactly nowhere.
Old 05-02-2023, 06:19 AM
its2loud its2loud is offline
That software by Radu Varga does work but you’ll need to set it up in conjunction with the Xmon software bundled with the Eucon installer. It’s not as clean of an integration with straight Eucon but you do get monitor control in Avid Control.
You’re basically tricking the Xmon app to control the Apollo via midi through the Radu Varga software. There’s a bit of midi mapping required but Radu makes this easy in his software.
PM me if you try and are having issues.
I could never get it to work in Mackie mode. Only via midi
Old 05-02-2023, 09:50 AM
Thanks very much for the responses Darryl and its2loud! While I did find the UA Midi Control app, I was not aware of Xmon app. This sounds promising, and I'll look into it.
Thanks again!
Monitoring with Avid Control and DADman ViciousLullabyz Avid S1, S3, Dock and Control App 6 07-31-2023 02:49 PM
Monitoring page blank in Avid Control with MTRX and MOM. uptheoctave Pro Tools | MTRX & MTRX Studio 9 01-23-2022 08:37 AM
Avid Control: Meters in monitoring tab JanuS Avid S1, S3, Dock and Control App 0 10-31-2020 03:11 AM
Avid Control Monitoring page with S1 Goombot Avid S1, S3, Dock and Control App 2 07-03-2020 09:28 AM
Monitoring through headphones with Apollo 8 - when selecting Low Latency Monitoring Mick335 Pro Tools 12 2 04-10-2018 08:34 AM
