Old 10-14-2022, 10:17 AM
milosziv milosziv is offline
Default Video Edit Frame Boundary Issue
I was recently conforming to a video edit that had changed, and I normally group all my old tracks (including video) and make edits on all of them and slide around until the conform is done. This time though, when I would make an edit on a frame, I'd see it actually cut it correctly on the audio tracks, but the video edit was on a frame early, or late. Depending on where I made the cut, it could be even 3 frames early or late - until you'd find a frame that was spot on. Anyone encountering this? I'm on the newest PT 2022.9.0, on a Mac Studio, and the QT's were H264's at 23.98
Old 10-14-2022, 10:25 AM
Pete Gates Pete Gates is offline
Default Re: Video Edit Frame Boundary Issue
Off the top of my head, might be because the h264 video is long GOP. You tried with an MXF picture instead?
Pete
Old 10-14-2022, 05:53 PM
Pete
No but thanks for pointing me down that direction - just read all about GOPs - and will try a conversion next time - just never hard to do this before. Many thanks Pete
HTML code is On
Bouncing Beyond Video Boundary Rectifried Pro Tools 1 05-24-2021 09:46 PM
AAF import frame boundary weirdness idris Post - Surround - Video 7 06-29-2015 01:07 AM
Trim tool requires breakpoint on clip boundary for "automation follows edit" to work simonchase Pro Tools 11 5 07-29-2014 06:41 AM
Video Not Syncing to Frame Nicol J Craig macOS 7 11-25-2012 04:57 PM
video on second screen lags on frame by frame moves gonzalo.garcia macOS 4 11-14-2012 09:13 AM
