Old 10-09-2010, 06:55 AM
epu epu is offline
Default No Audio, But Just Samples. System Drive Or Seperate Drive.
Built another PT setup at work which I will just use for VIs (no live Audio, or very little). This system uses standard HDDs. Should I leave my samples on the System Drive, or put both the Audio and Samples on the second drive? These VIs may be streaming lots of samples and using lots of effects. A third drive is NOT an option in this setup.
What would you recommend?
Macbook Pro 15" (Mid 2014)
16GB RAM
512GB SSD
Pro-Tools 12
2.5GHz i7 Quad Core
Old 10-09-2010, 09:38 PM
sw rec sw rec is offline
Default Re: No Audio, But Just Samples. System Drive Or Seperate Drive.
My 2 cents' worth would be, put the samples on your second drive. That way if you have a system crash you still don't lose your samples.
Now, I must ask...if it's a penny for your thoughts but you put in your TWO cents' worth, isn't someone doubling their money?????
Old 10-09-2010, 10:22 PM
nst7 nst7 is offline
If it's very little audio, you might be okay, but combining audio and sample streaming on the same drive is definitely not recommended.
Old 10-09-2010, 10:49 PM
TOM@METRO's Avatar
I have given up trying to balance these choices since expanding VI usage and have gone with a separate sample drive for the past couple of years, and have much better results.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 10-10-2010, 04:32 AM
MikeLip MikeLip is offline
Can USB2 hdd keep up for a VI drive?
-I know its not recommended, I'm just interested.
Mike.
This might qualify for "the best worded, but most idiotic thing I've ever heard said" award.-ejwells
Avid Pro Tools|HD Native 9.0.3. Win7x64Sp1. i7-930 X58A-UD3R. Acronis backup. Black Viper optimized.
Google the DUC
Search Avid
Old 10-10-2010, 03:47 PM
NO
Audio drive plus system drive, where Structure? Blustar Virtual Instruments 3 09-17-2008 04:01 PM
Do i realy need a seperate audio firewire drive rola 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 08-10-2007 12:54 PM
Audio drive Vs. System Drive with a Raptor gibson_sg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-30-2005 02:21 PM
scsi ultra160 disk for system drive and audio drive jazzle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-23-2001 06:54 AM
anyone using the system drive and storage audio drive in the same SCSI chain? riorecords 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-15-2000 11:09 PM
