Canopus, FW400, FW800, SATA, Oh MY!
Hey all!
Just upgraded to the new G5 and have several concert DVD projects coming up. I'm thinking the ADVC110 is the way for me to go, but, if I'm not mistaken, FW400 drives on the same bus as the ADVC would be bad, right? OK, so what would everyone recommend? I need roughly 1TB of drive space for audio at a time, so SCSI is cost prohibitive. SATA controllers aren't supported - any good reports from users would be welcome! How is everyone/anyone doing with audio from FW800 and video from ADVC? I could just do dual displays and skip the ADVC all together, but there are some particulars about my workflow that would make that a bit inconvenient. At the end of the day, if that is the best answer and just use FW400 for audio, so be it. I appreciate any and all help. peace mixboy
http://www.robburrell.com PTHD Ultimate/Eucon (latest betas) / Mac Studio Ultra 128GB RAM / Aja T-Tap / Sonnet M.2 4x4 PCIe 8TB / Focusrite 16Line / MTRX Studio / UAD Octo / 32 channel S1 & Dock (5) 2019 Fire HD 10 / Dolby Atmos 9.1.4 /Mastering Suite / 13.0 Sony 360RA |
Re: Canopus, FW400, FW800, SATA, Oh MY!
The easy and cheap way would be to get DVI to S-Video adapter and use the second output for the video monitor. You would then go into System Preferences>Displays, set the second monitor to 680X480, and drag the video window on to the video display. If you want to use a ADVC-110, the best way is to get a PCI firewire card and use it for your audio. You don't want to put the Canopus and video drive on the audio chain. That's asking for trouble.
Mark Ettel C.A.S. |
Thanks!!
I like cheap and easy, but I'm a big fan of doing it right, also. I guess that means I should go SCSI!! LOL! I'm a hypocrite... Will a PCIe firewire card interfere with my Expansion chassis by stealing from the bus? Thanks again. mixboy
Do you know if I can use two Apple displays with this, one for PT and one for picture monitor or do I need an NTSC? Is there a way to split the signal for ADR if I use an Apple display for control room picture? Thanks. I thought I'd let someone else think this one through... |
can't i have my dual monitor cake and eat the video monitor too?
Ken P. Pro Tools Ultimate, Mac Mini 3.2 i7, Mtrx Studio & Omni, 4x S1’s & Dock w/ iPad Air 2 |
> but what do you do in situations like this where you want to utilize dual monitors AND have a 3rd video out(<
If you want dual computer monitors, which is what I prefer, then you'll need a video decoder. Either a PCI card, like the Fuse-X, or a firewire device like the Canopus. The PCI cards are the more precise decoders, but the Canopus is fine for most work if you're just recording or mixing to picture. If I were mostly editing on the system, I would get a PCI solution.
Mark Ettel C.A.S. |
i would trust the DVI-->video method for sync, no drift and better scrubbing over a canopus. really big sessions, with lots of automation make the canopus drift.
so, if you can't do a PCIe solution, then use the cheaper, but better DVI-->video solution. aurora's FUSE-X for PCIe will be out soon , and AJA and Blackmagic have them out now. if you want. ATTOhas a PCIe card out now. just adding my thoguths...
Tom Hambleton CAS Ministry of Fancy Noises IMDb Undertone on Facebook Undertone Custom Sound Libraries "Groupable markers would be epochal!" -Starcrash |
i guess the one thing i have going for me is having a non-PCIe G5, so when the new Arora hits MAYBE i might catch a deal somewhere on a fine pre-owned fuse-x? sorry mixboy to bust in on your thread, just trying to clarify this canopus thing, so it might help us both out
[QUOTE]
If I would have known, I would have gotten Fuse-X instead. But then again I only have one more PCI slot and I'd like to get a Process card. |
I just got a G5 (dual 2.7) and am dealing with the same thing. I was worried about track counts and video playback, but I'm getting 100 tracks (constant, linear tracks) across 2 FW800 drives, video on the 2nd internal SATA and a Canopus on the 400 port—all with no troubles. in a G5, all firewire is on one bus, even with different port speeds. It seems to be able to handle it fine.
I would have preferred 2 SATAs for the audio, but all my slots are filled with HD cards. I have always had good luck with internal ATAs in the past |
FW400 HD on FW800 port? | toddw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 07-17-2009 08:49 AM |
FW800 -> FW400 Adapter for Macbook Pro | Mattitude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-22-2009 06:31 AM |
002 Rack Connection with FW800 and FW400 | dsk79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-16-2008 12:46 PM |
Is FW800 a different FW bus than the FW400? | Alex Rodriguez | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-17-2004 11:06 PM |
FW400 with FW800 | lancejorton | Pro Tools TDM Systems (Mac) | 12 | 05-08-2004 11:52 AM |
