Shortcut for switching nudge mode?
Does anybody know a way to switch the nudge mode between timecode and samples and vice versa via keyboard?
Sometimes there are undocumented shortcuts, that would help not using the mouse. (Sorry for any misbehavior in advance, I'm new to this thing here...) |
Re: Shortcut for switching nudge mode?
Press Command+Option and then "+/-" on the numeric keypad will change the value, but I don't know of shortcut that will change the time base.
Mark Ettel C.A.S. |
Hey wait a second. I almost forgot. Just click on the little "down" pointer to the right of the numbers in the Main Counter window in the Edit or Transport windows, and a drop down will appear. Then select the timebase you want.
Mark Ettel C.A.S. |
Thats no via the keyboard however.
Simon L. |
> Thats no via the keyboard however.<
Yeah, I Know. Just thought I'd mention it since it's handier than having all the rulers displayed that you want to switch between. They just take up screen real estate needed to display as many tracks as possible.
Mark Ettel C.A.S. |
Thank you!
I knew those ways. Maybe I should tell my problem more precise: Since I work in film postproduction I almost always work in grid mode with nudge switched to 1 frame. When I do dialogue editing, I often have to switch to samples (in the nudge window), because I want to bring the boom and the radio mics into phase and therefore a nudge of one frame is too rough. So I often see myself switching between these two values by clicking on this tiny triangle with the mouse. I hoped there would be an undocumented shortcut, but I think there is no. Something for my wishlist. |
@wildhoneymusic http://kidzbop.com/music/ https://concord.com/publishing-roster/gary-philips/ |
Nowadays, in the current version, we have access to SoundFlow.
For being a newb a couple versions in, I can say this would be a trivial few minutes work, and you'd have a keyboard shortcut ready to use. Also, you might pull off the same trick with the new Keyboard Shortcuts in the Setup menu. If you search for "counter" you can apply shortcuts to Bar/Beats or timecode or samples. Same as menu View > Main Counter. This could change the MAIN counter from timecode to samples. On the Nudge menu there is an option for "Follow Main Scale" which means if you change the Main counter by making a shortcut the nudge will change. Does this make sense?
___ >> me: nednednerB // ||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music // ||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 // ||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock // ||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR ||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts // |
I had created shortcuts for switching between Bars|Beats and Timecode, via macOS System Preferences->Keyboard Shortcuts, for when I was editing music to picture. It's even easier now to create these inside Pro Tools with the customizable shortcuts.
Scott Gatteño |
Change Nudge Value shortcut broken? | Kobra | Pro Tools 9 | 4 | 06-19-2013 08:14 AM |
Keyborad shortcut for nudge | ByPass | Pro Tools TDM Systems (Mac) | 5 | 01-31-2007 05:22 AM |
nudge shortcut? | bmuth | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-29-2006 03:20 AM |
nudge value keyboard shortcut bug? | inky | Pro Tools TDM Systems (Mac) | 4 | 06-16-2005 12:50 PM |
Shortcut for changing nudge value | Dopamine | Tips & Tricks | 3 | 08-11-2002 09:47 AM |
