hidden regions? alt takes not working!
I've posted this once before, but with no response, and wondering if anybody else is seeing these issues.
We seem to have "hidden" regions in our sessions which are adversely affecting the alt takes function as well as some less important editing functions. These regions are NOT overlapping regions, but regions which are totally covered by a forefront region. The problem occurs most frequently when recording multiple takes in the same playlist a the same place in the timeline. When we try to call up an alt take, the issue above confused Pro Tools and calls up and incorrect take. In addition, when attempting to highlight the most forefront region, the "hidden" region will highlight, obstensibly highlighting only a portion of the visible region. (This is when double clicking to highlight a region.) This issue is also affecting focus mode editing. Anybody come across this problem? This is occurring too often and seems too bizarre for us to be the only ones to have come across it. Thanks in advance, Matt Grimm
PT HD Native 11.3.1 Windows 7 sp1, Intel i7-4770 @3.4 gh 32 gigs ram PT 11 HDN Omni |
Re: hidden regions? alt takes not working!
We've had the problem as well with PT 7.2 . . . anyone from Digi CS willing to chime in to answer this?
Found a thread yesterday that may more clearly define the problem, but still no solution. Apparently Digi has not yet been able to reproduce the problem. Partially because it is so intermittent.
My guess is that newer region overlapping behavior introduced in 7 and 7.2 is where to start looking for coding errors since the problem never occurred for me before that upgrade. Here's that thread, if anybody can make this a reproducable (sp?) error, please email Digi and I'm sure they'll be on top of it. http://duc.digidesign.com/showflat.p...7189%231053183
Yes - if you have a session that is exhibiting this problem, we'd really like to get our hands on it, as this has been an extremely difficult problem to reproduce. The session will need to contain all your audio files - we've had customer send in sessions without the audio files and we weren't able to repro the problem with their session, so we need one that has everything in it.
I can send a Digidelivery of the offending sessions to DigiTS, who should I send it to (email address). We are installing 6 other PT7 upgrades in our other rooms this weekend and I will see if the problem is common on all rooms.
If the problem is not repeatable in the other rooms then I will just do a full re-install in that room. Anyway if it is a common problem, then I will send via Digidelivery the session for TS to study. |
Going through takes from loop record and the regions move out of time... | luisam | Pro Tools 9 | 0 | 02-03-2011 12:45 PM |
Naming regions with incrementing takes issue w/solution | BillyT | Pro Tools TDM Systems (Mac) | 9 | 10-29-2007 10:17 AM |
selecting alternate regions/Matching takes | dcrann11 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-13-2006 06:38 PM |
Matching takes not working in 7.2 cs1 | dj_grimmace | Pro Tools TDM Systems (Mac) | 0 | 10-26-2006 08:44 AM |
Hidden Audio Regions List | CooperG | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-05-2005 02:38 PM |
