I want to use TDM, DAE, + Digital Performer ...
I've been a TDM/DAE/Digital Performer user for some time now. As the years have gone by, some features in DP [automation data, for example] seem to behave erratically under this set-up. I've spoken with MOTU, and they claim they are powerless to fix some of these matters. Could someone tell me if the time has come to take sides, or will Digi + MOTU come together ?
Due to the current state of affairs, I'm compelled to run DP + PT concurrently. I've seen documentation on the MOTU site with respect to using OMS emulation mode. Isn't it also now possible to run the 2 programs together under actual OMS, and if so, how is this done ? Also, if the 2 techniques are viable, which works better ? Thanks, Jep Epstein Score Music, Inc.
PT HDX - PT 23.9.0.155 Mac Studio M1 Ultra - 128gigs RAM - HD/IO with A/D Expansion -Sonnet Echo Express III TB3 upgrade - OS 13.4.1 |
Re: I want to use TDM, DAE, + Digital Performer ...
Here's the process for using OMS with DP:
-Install OMS 2.3.8 and then run the FreeMidi 1.4.x installer. Installing FreeMidi after OMS will then update the System Folder>OMS Folder with some MOTU specific files which may give you the functionality you need with your setup. Restart the computer and launch FreeMidi. It will say something like “FreeMidi has detected OMS...Do you want to use FreeMidi or OMS?” Click “Use OMS”. This puts FreeMidi into OMS compatibility mode. From this point on, FreeMidi will reman invisible to you and all configuring/editing of interfaces and devices is to be performed in OMS. Brent |
Thanks for the reply, Brent ...
jep
BTW are the MOTU plug ins, TDM compatible or do you still have to use the MOTU audio engine ?
phil |
MOTU plug-ins, I believe, cannot be used while running under DAE [MAS is required]
jep
I'm a long-time DP user myself, who recently upgraded to Pro Tools Mix Plus. Needless to say the midi in PT sucks s**t, so I spend a lot of time running both programs, or sticking with Pro Tools if I feel I can muddle through with their lame midi while I wait for 5.1 (event lists - PLEASE!!!)
Jep - when you use DP with the DAE, do you have problems? DP crashes right and left for me if I run it with digital audio enabled. What kind of system are you running...? |
Anyone using Digital Performer with LE ? | therockstar30 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-16-2006 08:58 AM |
OT - Digital Performer | stanonbass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-01-2005 12:12 PM |
Digital Performer 3 | Musick | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-22-2004 07:07 AM |
anyone using digital performer 2.7? | coaster | General Discussion | 15 | 03-01-2001 12:35 AM |
Digital Performer/Performer and the 001 | nz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-01-2000 01:08 AM |
