Old 05-23-2005, 08:26 AM
pacodub pacodub is offline
Default Problems Recording for a newbie...
I just got the Mbox a few days and have been playing around with it.
I having problems recording in stereo. Everything is on a mono track.
The first thing I do is create a new session and add tracks. When I add tracks I choose stereo and not mono. I can hear myself play in stereo but playback and bounce the tracks all record mono.
Can anyone help?
Also, I did notice when I bounced the session I have a left and right. Is there a way too bounce it where it one file to record to disc. I wasnt able to find it in the getting started manual.
Eddy
Old 05-23-2005, 08:28 AM
scottedog scottedog is offline
Default Re: Problems Recording for a newbie...
Bounce using "Stereo Interleaved", make sure you're a 44.1k & 16bit to be able to play it in a CD player.
Scott.
ScottedogStudios on ReverbNation
Old 05-23-2005, 08:37 AM
gravityspull gravityspull is offline
Hi Eddy,
first things first, the bouncing problem is straightforward: in the BTD dialogue box make sure that "format>stereo interleaved" is selected, not 'multiple mono' etc. This will give you a stereo file of your bounce, though you can still import back into PT and edit the individual L and R tracks if needed.
Secondly, if you are recording with two inputs into a stereo track, make sure that you can see both the L and R inputs receiving a signal and you've chosen the hardware inputs that you want. This should work if you can hear stereo when monitoring - have Auto-input monitoring on in the Operations menu and record-arm the track. Also check the pan, make sure your stereo inputs are panned hard left and right to be sure.
good luck, hope that helps
Old 05-23-2005, 08:38 AM
awesome thanks Scott!
How about the recording in stereo? I see the track has 2 section, but for some reason it only takes up one of the section (mono)
Old 05-23-2005, 08:54 AM
Sounds like you're only using one input, if you're recording a synth for instance, use both outputs of the synth to 1 & 2 line in on the 002r. I personally don't record many things in stereo though.
Scott.
Old 05-23-2005, 09:55 AM
SeanDempsey SeanDempsey is offline
What is it you are trying to record in stereo, but it's only giving you one channel? That'd help alot.
Old 05-23-2005, 09:56 AM
aaah...so thats normal i take it then that it normally just records to either left or right channel?
I using a bass in one input and the other for guitar.
Old 05-23-2005, 10:03 AM
millicent frndly millicent frndly is offline
Yea, when you record a mono instrument such as guitar or bass (unless your using some kind of stereo effect or something) you should just use a mono track... then you can pan it whereever you want in the stereo mix. Keyboards, drum machines should be stereo but don't really HAVE to be).
you'll get the hang of it. Read through the manual a bit... believe it or not, it's a big help.
chris
Digi 001/WinXP Home
A7N8X Dlx
AMD 2500+ Barton
1024mb DDR PC3200
Maxtor 40gb System and 60gb Audio drives
www.millicentfriendly.com
Old 05-23-2005, 10:11 AM
you guys are awesome...i'll try that tonight..wish me luck =)
Old 05-23-2005, 10:30 AM
spkguitar's Avatar
Some other areas of interest for learning:
The DiskFlix instructional videos... the very basics PT
LE Bootcamp archive from the digizine
The Project Studio Handbook General recording info
and many of the other links from the Education link from the top of this forum.
Help with live recording for newbie corson57 General Discussion 10 12-26-2011 07:57 PM
PT9 newbie, need recording help ADubecky Pro Tools 9 15 05-03-2011 09:49 PM
newbie?? PT8 Not Recording Tracks metlgod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 03-06-2009 03:21 PM
Newbie Help Recording Volume batchmister1 Pro Tools M-Powered (Win) 3 06-17-2007 10:50 PM
newbie recording ? daveo32 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-23-2004 11:19 AM
