OMF import does not bring in volume info
We are receiving an omf output from Avid Media Composer v3.12. All is perfect EXCEPT their volume rides are not coming over. In the session input
preferences it is selected to import all information, including volume. Any info would be a great help. Thanks very much. Mel PT 8.0.3cs1 HD1 Max OSX 10.5.8 |
Re: OMF import does not bring in volume info
Check with the pix dept and make sure that when they created the OMF for you, that they exported the volume info in the first place.
Hope this helps, Joe |
Are you referring to the drop down list on the right? That is for importing data from other Pro Tools sessions (such as playlists, plug-in settings, ICON maps, etc). You need to either select from the bottom left of the import window the "Convert clip based gain to automation," or if they have key-frame gain, make sure the "Ignore Keyframe gain" box is unchecked.
Thanks for the info. That was it.
Mel |
it is my experience that the volume from the Avid does not relate to what I hear in the audio room.
I usually strip all of it off.
Ray Trujillo Freelance Audio Engineer |
Agreed, it's pretty much useless, you'll be fighting it the whole time. I always ignore clip and keyframe gain. Now that you know how to import the data, ignore it.
More than ever before I am getting audio clips that should not be included, with their volume turned all the way down. Sometimes they are alts and sometimes they are just forgotten garbage. Importing the automation helps me check specifically for what is not used, THEN I can ignore it all.
I think it is bad practice for the editors to leave that stuff strewn around, they ought to make a pass to clean out garbage. |
Good point. Definitely bad practice. It would be nice if our editors did any sort of automation on the garbage so we would have an idea if it was supposed to be included. If they did, I would probably import the data then remove it after sorting through the mess they gave me.
Hey Joe, Doing a small INDIE film as a favor for someone and for some reason I am having trouble exporting a music omf embedded/consolidated in Protools 9.0.5 and then importing it back into a Dialogue/FX Mix Session with all of my settings, such as Volume and PlugIns)reverbs). I need them for the mix adjustments I did in the Music Session. Would rather do all of the parts there rather then mix it before hand with the rest of the film audio. It used to work, but not sure what it's not now. Thnx in advance! G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.5, DP 11.3, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
Session import won't bring in audio files | belolab | Pro Tools TDM Systems (Mac) | 1 | 07-30-2012 04:21 AM |
How To Import Mix Info from Another Session | jackostrato | Pro Tools 9 | 3 | 04-10-2011 03:13 AM |
OMF with volume info from Logic to ProTools... | 24bit dither | Pro Tools TDM Systems (Mac) | 2 | 03-14-2006 03:29 PM |
Help! volume send info driving me mad. | crizdee | Pro Tools TDM Systems (Mac) | 2 | 10-21-2005 03:40 AM |
what is key frame volume data? (from 5.1.3 info) | Michael Klinger | Post - Surround - Video | 2 | 12-06-2001 11:03 PM |
