#31
Re: AIR Patchbay
Bloody great idea Russ.
-------------------------------------------------- Why do people keep running over a string a dozen times with their vacuum cleaner, then reach down, pick it up, examine it, then put it down to give the vacuum one more chance? |
#32
Re: AIR Patchbay
Just posted the beatcutter settings.
I work with amazing people who do incredible things. Founder of the Expert Sites. |
#33
Re: AIR Patchbay
I added a bunch of Structure Presets to the AIR Patchbay.
These are the current Air Blog, Goliath and Structure Free and Structure Factory Libraries saved as Settings/Presets. You may have to direct Structure to your patches depending on where they are located on your hard drives and then re-save, Save Settings (Command/Control+Shift+S) the preset and you should be fine. Hope this helps.
Pro Tools 10.3.9, MBP 2.4GHz Intel Core 2 Duo OS 10.6.8 4GB/Ram, 7200RPM 750GB Internal HD, Focusrite Saffire Pro 40, Digidesign Mbox 2. It is what it is... ScrewMakerMusic Last edited by ankely; 11-22-2009 at 12:20 PM. Reason: Updated info. |
#34
Re: AIR Patchbay
Community member Martin has created a nice set of Moog type sounds for Vacuum which are now on the patchbay
#35
Re: AIR Patchbay
So, I know I'm being dense, but how do I get to this patchbay / ftp site?
Bob Simpson |
#36
Re: AIR Patchbay
#37
Re: AIR Patchbay
I went to the website...
Entered info into FileZilla, keyed in the password, and got this: Status: Connected Status: Retrieving directory listing... Command: PWD Response: 257 "/" is your current location Command: TYPE I Response: 200 TYPE is now 8-bit binary Command: PASV Response: 227 Entering Passive Mode (69,175,8,218,91,56) Command: MLSD Response: 550 Access is denied. Error: Failed to retrieve directory listing Any pointers on how the make this work? TIA Bob Simpson |
#38
Re: AIR Patchbay
Here you go...
Filezilla (for Windows) FTP configuration SFTP configuration Instructions (new window)
#39
Re: AIR Patchbay
Finally got round to trying these out. I really like them. Now, I need to find some way to use them in something I'm working on!
#40
Re: AIR Patchbay
I updated the info and instructions for the Structure collection of settings called, Structure Presets 09082009:
----- These are the current Air Blog, Goliath, Structure Free and Structure Factory Libraries saved as Plug-in Settings. For these Plug-in Settings to work, you need to have these sample libraries loaded onto your hard drive. These Plug-in Settings will need to be unzipped and copied into your Plug-In Settings folder located here: On the Mac: Library/Application Support/Digidesign/Plug-In Settings/Structure On the PC: Program Files\Common Files\Digidesign\DAE\Plug-in Settings\Structure (See Chapter 41: Plug-in and Hardware Inserts, pg. 887, of the Pro Tools Reference Guide for more information). As you load these Plug-in Settings from the Structure Plug-in Settings Menu, you may need to redirect Structure to where the Structure sample libraries are located on your hard drive so that Structure can load the samples. If a dialog opens asking you to "Choose a Root Directory for xxx missing audio files", choose the folder containing your samples, check "Full Recursive Search," and click "OK." (See Chapter 5: Structure Parameters, pg. 43, of the Structure Plug-in Guide, for more information). Once the samples are loaded, you will then need to re-save the Plug-in Settings using, Save Settings (Command/Control+Shift+S), so that Structure will now be able to load the samples properly for your setup. More info here: http://airvirtualinstruments.blogspo...ick-video.html ------ Hope this helps.
Pro Tools 10.3.9, MBP 2.4GHz Intel Core 2 Duo OS 10.6.8 4GB/Ram, 7200RPM 750GB Internal HD, Focusrite Saffire Pro 40, Digidesign Mbox 2. It is what it is... ScrewMakerMusic Last edited by ankely; 11-22-2009 at 12:21 PM. Reason: Updated info. |
Patchbay | Nightworker | General Discussion | 2 | 08-23-2012 03:49 PM |
Help with patchbay Please | spurboxer | Pro Tools TDM Systems (Mac) | 5 | 03-21-2006 07:32 AM |
patchbay? | vx2kfilmer | ICON & C|24 | 5 | 10-30-2004 11:22 AM |
to patchbay or not to patchbay (micpres) | Camilo Orozco | Tips & Tricks | 10 | 12-07-2001 12:51 AM |
TT patchbay, or TRS? | blake eat world | Tips & Tricks | 6 | 06-15-2001 01:33 AM |
