Old 09-01-2009, 08:39 AM
djmichael.london djmichael.london is offline
Default Apple loops in PT
Help. I converted some Apple loops so that I can use them in PT. and the song I created in Garage Band when tried in PT all the loops are in a very slow tempo and they are all off from each other. How do I solve this?
MichaeLondon
Mac : IMac 3.0 ghz/OSX 10.6.8/Mbox Mini/PT 7.4.2
DAW : Pro Tools 7.4.2 - Mbox Mini
www.myspace.com/michaelondon
Old 09-01-2009, 09:30 AM
Default Re: Apple loops in PT
How do I keep them the same tempo when they are in Garage Band?
MichaeLondon
Old 09-01-2009, 12:06 PM
Jussi Jussi is offline
1) Freeze the tracks in GB, then import them to PT (I think they are to be found on your GB session folder, a sub-folder there).
2) Or, if you want to import just the loops, set yor PT session exactly to the same tempo as the GB session, then open workspace in PT, find the loops and drag them in to the PT session, elastic audio should take care of the tempo (if there was a setting in prefs or something for this, I don't remember, someone else may).
mp (8x2,8ghz 8gb) mbp (c2d 2,53ghz 4gb) osx10.6.3 pt8.0.3 mptk2 mbox2
www.myspace.com/pukspace
eSoundz name: jus11
Old 09-01-2009, 01:34 PM
So if the loops are imported in rather than thru workspace will the elastic audio not work?
MichaeLondon
Old 09-01-2009, 03:37 PM
PaulV's Avatar
PaulV PaulV is offline
That's right - it needs to be through the workspace (and with Preview / Import at Session Tempo on - the metronome icon in the workspace browser).
Cheers,
Paul Vercellotti
Avid Engineering
ACID WAV loops vs. Apple Loops scripguy macOS 1 05-18-2012 10:44 PM
Using Apple Loops porkipine 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-09-2007 04:32 PM
Apple Loops and .caf files Brett Belcastro Pro Tools TDM Systems (Mac) 2 07-16-2007 03:37 AM
Apple Gargeband Loops roberts Pro Tools TDM Systems (Mac) 0 01-03-2006 10:10 PM
Apple Loops in Protools Marketis12 Pro Tools TDM Systems (Mac) 1 04-20-2005 08:16 AM
