  #21
Old 01-27-2023, 08:48 AM
EddieJones's Avatar
Default Re: EUCON 2022.12 Released
Originally Posted by IrelandM View Post
Yes,Eddie
I'm not 100% sure what your question is?
  #22
Old 01-27-2023, 09:14 AM
IrelandM IrelandM is offline
Sorry Eddie,
Is the xml file required if I have installed the 2022.12 Eucon update.
creative control said ''Yes - you would need to add the Copy Plug-in function - either globally or track based - to Channel Strip Keys. I'll post my default set you can play with and check out here shortly''.
  #23
Old 01-27-2023, 09:28 AM
EddieJones's Avatar
Sorry Eddie,
This is the S6 forum. Thats why it's getting confusing. For EuControl Surfaces like S3 the Copy and Paste is on the Control App only.
  #24
Old 01-28-2023, 04:12 PM
James Steele's Avatar
James Steele James Steele is offline
My apologies if my post re: Artist Control was in wrong forum. I understand it's not supported. When I first got this (Euphonix) MC Control unit, I did a good deal of experimenting with different Eucon versions and noticed that there were some what affected the display and caused various issues. 2022.9 seemed to be just great. 2022.12 seems to cause the issue I described.
It's too bad as I did discover some new functionality in DP (I use it with both PT and DP). A small "i" appeared on channels in my MC Mix indicated that an audio track input was enabled. I know that wasn't there before.
Either way, again, I recognize the Artist series isn't officially supported so it may be that reproducing and fixing this issue may not happen. 2022.9 continues to work well here.
  #25
Old 01-29-2023, 08:10 AM
EddieJones's Avatar
This issue is that Apple change the way they do screen drawing every relese....even dot releases. EuControl pre draws the screens both the TFT and OLED's and then sends them over to the surfaces. We try to keep up and make changes, try to match MacOS versions but its a never ending task.
  #26
Old 01-29-2023, 12:24 PM
I hear you. And I sympathize as it seems Apple is always throwing curveballs at third-party developers. The only thing that changed for me was going from Eucon 2022.9 to 2022.12. Eucon 2022.9 didn't have a problem with MacOS 12.6.3 (or vice versa)... but something changed in Eucon 2022.12 that affects how the colors look on the display on my MC Control v2.
Again... I recognize that this comes with the territory when one is pressing older, un-supported gear into use. There are many pitfalls you have to avoid to keep these things working in the way you hope for. It may be that when the coast is clear and I decide to go to Ventura, I'll try 2022.12 again. Thanks for your help and the explanation.
  #27
Old 02-01-2023, 01:20 PM
EddieJones's Avatar
Can I ask you to post a before and after picture....I'm starting to think this could be due to a change to make softkey feedback better (On/Off states)
  #28
Old 02-01-2023, 03:14 PM
Sure.... I think I posted a comparison pic earlier that showed from top to bottom what it looked like on Mac screen, then on the MC Control screen with 2022.12 and then with 2022.9. I'll post that first... then before and afters. I didn't really take extensive pics where you can see the tracks which I think looked normal. It was the color of the soft keys that was off.
I suppose since I'm on Monterrey and it's not too hard to do a rollback using an APFS snapshot, if you have something specific you'd like a before and after of, I could set that up. Hopefully won't need to.
  #29
Old 02-02-2023, 08:06 AM
EddieJones's Avatar
We are not seeing this here. All the colors look good. What version of Monterey are you on? 12.6.3?
  #30
Old 02-02-2023, 09:45 AM
Yes. 12.6.3. Maybe it’s because I’m on a Euphonix MC Control v2. I believe it has the latest firmware.
M1 Max Mac Studio, 64GB/2TB, macOS 14.5 Public Beta, DP 11.31, Pro Tools 2024.3.1, MOTU 828es, MOTU 24Ai, MOTU MIDI Express XT, UAD-2 TB3 Satellite OCTO, Avid S3, Console 1
EUCON 2022.12.1 Released EddieJones Avid S1, S3, Dock and Control App 94 07-19-2023 09:13 AM
EUCON 2022.9 Released EddieJones Avid S1, S3, Dock and Control App 18 02-28-2023 08:12 AM
EUCON 2022.9 Released EddieJones Avid S4/S6 4 09-27-2022 08:09 AM
EUCON 2022.4 Released EddieJones Avid S1, S3, Dock and Control App 17 05-08-2022 07:26 PM
EUCON 2022.4 Released EddieJones Avid S4/S6 0 04-29-2022 03:32 PM
