Old 07-11-2019, 07:57 PM
firmflange's Avatar
firmflange firmflange is offline
Default Consolidating problem on 12.5
Help!
Trying to exhaust all the possiblities for posting this, I've come across a situation here:
All tracks sent to a mixbus
Print track: INPUT: Mixbus
OUTPUT: 1-2 (Speakers)
Printing to the new track works fine, as in all sessions I have, but on a couple sessions, when I want to consolidate the printed waveform, it compresses quite heavily.
I have to effects on any insert or send on the print track that would cause this to happen.
Automation mode selectors are set to "off" on all tracks.
Other sessions work fine and the consolidated track is not compressed.
I just don't understand since there's nothing that would cause the waveform to compresss...why would it compress after being consolidated?
PT 12HD Native / 192 / Yosemite / Cheese Slicer 3.33GHz 12-core / SSD Hard Drive / 32GB RAM
Slate Raven MTi2 / Artist Control
Old 07-11-2019, 11:15 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Consolidating problem on 12.5
Export the waves and make a new session and setup the flow again
See if it happens again
Might just be a session io that has gone flaky
Daniel
Old 07-12-2019, 10:45 AM
The Weed's Avatar
The Weed The Weed is offline
Stab in the dark. Do you have Elastic Audio turned on on the track inadvertently?
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 07-13-2019, 03:05 PM
firmflange's Avatar
Ya just checked. Elastic is off. It remedies it when I do a copy the session tracks to a new session, but for some reason levels get affected.
Consolidating vajoiner_ Tips & Tricks 4 05-01-2018 03:02 PM
Consolidating basslik macOS 6 11-02-2013 12:41 PM
Problem with consolidating... barstool719 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-11-2009 08:33 AM
Consolidating Tracks lamp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 05-23-2006 11:23 PM
consolidating surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 06-28-2001 09:54 AM
