Old 05-16-2022, 08:43 AM
furia70 furia70 is offline
Default Eleven rack newest drivers don't support 48khz sample rates
I just downloaded the newest drivers as of 5/13/2022 and noticed that Eleven rack doesn't support higher sample rates than 41khz. I was able to change the sample rate manually and automatically with the previous drivers. I am on a powerful PC system. Any solutions to this?
Old 05-16-2022, 08:49 AM
Default Re: Eleven rack newest drivers don't support 48khz sample rates
There are no drivers new as of 2022.
The latest drivers on Windows were released April 22, 2021, presumably you installed that.
The Eleven Rack absolutely does support higher sample rates with all drivers and if it didn't you would have had people screaming about it for years.
I suspect you have the Eleven Rack set to clock to an external source, it's not anything to do with drivers.
The "power" of your computer has nothing to do with what sample rates the Eleven Rack will run at.
IIRC you cannot change sample rates on the front panel if the Eleven Rack is connected to USB.
S3 AVB support for high sample rates LukeHoward Avid S1, S3, Dock and Control App 10 09-15-2015 01:55 AM
The Current Playback Engine Does Not Support a Sample Rate of 48Khz justus1900 Pro Tools 9 14 10-23-2012 01:45 PM
Eleven Rack Sample Rate/ Internal Clock fixed at 48khz?? Imran5000 Eleven Rack 3 07-07-2012 10:54 AM
Newest ASIO drivers for 002 Rack/PTLE 6.4? spinweb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-11-2007 10:34 AM
PTLE 5.3.1 with higher sample rates that 48khz? Pako 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-14-2002 05:58 PM
