Old 01-22-2022, 08:15 AM
fredley fredley is offline
Default Mac no longer sees Eleven Rack
I'm running Catalina 10.15.7 on a 2014 MacBook Pro. Yesterday, everything worked fine using my Eleven Rack as an audio interface. Today, my Mac no longer sees the ER as an audio interface. It doesn't show up in the Audio/Midi setup. The weird thing is that I can still use the ER editor to manipulate everything on the ER. Before they released the drivers for Catalina, my ER editor did not work. Why does everything work with the editor but it no longer sees ER as an audio interface? (I did try uninstalling and re-installing the drivers - no difference.) Any ideas?
Old 01-22-2022, 08:19 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: Mac no longer sees Eleven Rack
Hi, welcome to rthe community.
https://pbs.twimg.com/media/FJsiDyTX...pg&name=medium
Janne
Old 01-22-2022, 09:53 AM
The MIDI control used by the Eleven Rack is quite separate from the audio driver.
What if anything have you changed?
Does AUDIO/MIDI setup show the Eleven Rack as an audio device?
Likely reasons the audio device may not show up are…
1. You installed a driver yet did not approve its install in the security preference panel. The option to do that goes away after 30 minutes, rerun the driver install and approve its install.
2. You allow the computer to sleep/suspend with the Eleven Rack attached and powered on. That is working as badly as designed, You cannot do that, make sure your Mac is properly optimized to not sleep/suspend (and don’t close the lid to cause it to).
3. The Eleven Rack has a hardware problem. But try other USB ports on the computer.
Maybe you did #2 then #1?
Old 01-22-2022, 10:00 AM
Originally Posted by JFreak View Post
A attempted spark of Finish humor?
Old 01-22-2022, 10:24 AM
JFreak's Avatar
whoopsie, mistake in copy and paste. my bad. slight problem on my wrists and hands now..
https://avid.secure.force.com/pkb/ar...n-Rack-Drivers
Janne
Old 01-22-2022, 11:51 AM
Wow! I did not know about this security preference time-out! Thanks, that did the trick!
Old 01-22-2022, 12:03 PM
Great! And yes welcome to DUC.
The timeout especially tricks lots of folks. I wish Apple did something like a greyed out list of past install attempts there, with a note to try to reinstall.
And on behalf of everybody on DUC I apologize for you having to see a Finish cartoon
ProTools 2018.4 No Longer Muting Eleven Rack hco7777 Pro Tools 2018 1 05-25-2018 11:35 AM
PT10 "sees" Eleven Rack as playback engine only (no editor window,embedded rigs,etc) locust_tree Eleven Rack 4 12-08-2014 03:16 PM
Eleven Rack no longer available on GC/MF derker Eleven Rack 10 03-10-2013 10:19 AM
Eleven Rack window responds to changes on Eleven Rack, unable to record. pine Eleven Rack 6 08-02-2012 07:50 PM
Eleven Rack and Eleven Rack control window not matching 11R Newbie Eleven Rack 3 04-18-2012 06:07 PM
