Old 02-24-2012, 02:37 PM
fulltato fulltato is offline
Default Digi 003 and Pro tools 10 problems
[QUOTE]I Am running pt 10.0.1 win7 64 bit , digi 003 system . I am unable to record using other than 1024 buffer . My click track and virtual instruments would start playing after 2 sec and suddenly like it was stuck. Some times click track would play an extra beat even after the audio stopped already . If I cant use a buffer size other than 1024 , pt 10 is useless sort of speak . Some other people have reported Similar cases . I think there should be more people reporting about this than i have found, anyway, I would like to hear from people with the same issue as mine as well as from people with the same setup and everything working as it should. Thanks
Old 02-24-2012, 05:17 PM
HKnight HKnight is offline
Default Re: Digi 003 and Pro tools 10 problems
I have the same limit in ProTools 10 with Mbox 3 Pro...and my ProTools 8 LE with mbox mini 2 allowed up to 4096. Go figure!
Corsair 800D Case w/750w corsair psu
Asus P6X58D-E
Intel Pentium I7 - 930
NVidia GTX 650 2GB DDR5
12GB OCZ DDR3 Ram
1 - 128gb Samsung SSD
3 - 2TB Seagate 7200rpm harddrives
Phillips Bluray 12x burner
Mbox 3 Pro w/ProTools 10.3.9
Windows 8.1 64Bit Pro
Old 02-24-2012, 08:54 PM
As for 4096, that was an anomaly that only appeared in that one version, and in my testing, it offered zip. Having said that, back to the OP, did your system work well with any older version of Pro Tools? If not, posting a Sandra report might get more and better solutions.
Help us Help You - READ THIS Before Posting! right above your original post.
Pro Tools 9/Digi 002 Problems DirkStruthers macOS 14 06-19-2012 08:02 AM
problems with my pro tools digi 003 shawtie305 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 02-25-2009 06:57 PM
PROBLEMS with Digi 002 & Pro Tools 7 (Firewire ) May Day 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 12-08-2005 10:39 AM
help problems with my digi 001 and pro tools le gregoryb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-04-2002 12:52 AM
help problems with my digi 001 and pro tools le gregoryb General Discussion 0 08-31-2002 05:48 PM
