Old 02-26-2010, 11:55 AM
MrKnewitAll MrKnewitAll is offline
Default Has 'Export Region Definitions' stopped working?
I haven't used 'Export Region Definitions' in a long time, but when I tried to recently and again today, it did not work.
I select a region in the region list, click on "Export Region Definitions...", a dialog opens, I click "Export" and nothing happens.
The modified date of the source file is unchanged, and when I try to import that region, it doesn't show up in the import window as it had in the past.
All of the posts here lead me to believe that everyone thinks it does not work.
Does it work for you?
I've tried this on 7.4.2, and 7.4 and on several different systems in our studio but it does not export a region definition any more as far as I can tell.
Anyone who isn't confused, really doesn't understand the situation.
Old 02-26-2010, 01:29 PM
mgrimm mgrimm is offline
Default Re: Has 'Export Region Definitions' stopped working?
Works fine for me. You won't see any processes occurring after you click 'export.' When you try to import the parent file, you should see the region definitions directly under the parent file you are trying to import in the "regions in current file" window of the import audio window.
I'm on PT 7.4
Old 02-26-2010, 07:02 PM
Yes, that's what I'm expecting to happen- but it just doesn't happen.
Importing the file back in to protools, all I see is the parent file in the import window. Odd...
Tab to next region stopped working in PT HD 8.0.3 Questar Pro Tools TDM Systems (Mac) 2 01-15-2010 11:14 PM
[Trying To] Export Region Definitions Sound Guy Andy Post - Surround - Video 1 07-24-2009 06:07 PM
Region matches/definitions not working Sound Guy Andy Pro Tools TDM Systems (Mac) 1 07-22-2009 07:08 PM
Region Definitions between PC .WAV and MAC .WAV? blairl Pro Tools TDM Systems (Mac) 0 09-05-2006 11:31 AM
Export Regions Definitions quit working!! jkelehear 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-20-2005 07:38 AM
