Old 02-09-2010, 01:57 PM
msgood msgood is offline
Default Otpimizing Xpand for EWI 4000s midi controller
The Akai EWI 4000s is both a wind synth and a midi controller. When I play my EWI 4000s straight through an amp using its internal sound bank, it sounds great. However, when I play it through my MBOX2 audio interface and use it to control virtual instruments in Xpand! or Structure (both RTAS plugins), I find the EWI is not as responsive - notes seem to "stick" and it's not possible to play fast runs. Any idea how I can get the same responsiveness playing virtual instruments as I do when playing the EWI alone? I don't have much experience adjusting the settings in Xpand or Structure to respond to breath, so any help would be appreciated.
Thanks,
Mike
MacBook Pro 15.4 in, 2.6 GHz Intel Core i7 Quad-Core, 16 GB
Pro Tools 2018.10 running on OS Sierra
Glyph BlackBox Plus 1TB audio drive
Scarlett 18i8
Presonus Eris 4.5 monitors
Komplete Kontrol A49
Akai EWI 4000s midi wind controller
Old 02-09-2010, 02:58 PM
promixr promixr is offline
Default Re: Otpimizing Xpand for EWI 4000s midi controller
Do you have any stand alone virtual synthesizers that you can test this with?
Also are you using the MIDI input of the MBox?
Keep in mind that the module that you are using is especially 'set' up to take advantage of breath control information etc... from the EWI, so it does not surprise me at all that Structure and Xpand to not perform like your module... you may have to get deeper with assigning controllers to certain parameters at the patch level..
Eddie Sullivan
Long Island Mac Tech
http://long-island-mac-tech.com
[email protected]
631 786 3924
Freelance Mac/Pro Tools tech for hire. Metro New York Area.
Old 02-09-2010, 03:59 PM
TwinSnakes007 TwinSnakes007 is offline
Since you have wind controller, you HAVE to check out the WIVI RTAS Demo.
WIVI Instruments
Old 02-09-2010, 05:12 PM
I'm using the MBox's MIDI I/O. What do you mean about assigning controllers at the patch level?
Scarlett 18i8
XPand sound module & midi controller question RichrdC Pro Tools M-Powered (Win) 7 04-13-2009 12:26 PM
Triggering Xpand via Midi Controller (MPC 2000XL) variation 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 03-31-2008 08:14 PM
No midi playback - M-Powered ProTools, EWI 4000s, Mobile Pre msgood MIDI 0 07-08-2007 10:14 AM
Need a MIDI controller for my Xpand samples M Audio or AKAI? HipHopHead Virtual Instruments 4 04-09-2007 02:34 PM
help otpimizing computer for better performance corruptedshane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-29-2006 07:21 PM
